Hİ K53SD REV5.1 BİOS DUMP VERSİON 208 Need please help
Asus K53SD v. 5.1 bios
Good evening. I own an asus k53sd with mb version 5.1. The laptop turns on but does not show anything on the screen. voltages are ok. I dumped the bios with a CH341a and the file is 65kb big. The original Asus bios file is too big to load. I understand that I need to extract only a part of the original file, but I can't figure out which one. Can anyone help me ? Thanks
Re: Asus K53SD v. 5.1 bios
Originally posted by ManuCE View PostThank you very much. Can you help me ? Which part of the "Intel image" should I upload to the Mb ?
The complete file is too big !
Can you tell me how to do it?
Make 2 backups first, compare the files with HxD hex editor,look at both just make sure there`s some code in them.The backups should be 8MB not 65kb. Post your backup here before flashing any other bios
https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
HxD https://mh-nexus.de/en/hxd/Last edited by SMDFlea; 09-14-2021, 02:43 AM.
Originally posted by ManuCE View PostHere...thank you for the help.Last edited by SMDFlea; 09-14-2021, 04:52 AM.
Originally posted by SMDFlea View PostThe chip you selected is only 512kb .Find the bios chip,then don`t auto-detect select it manually,look at the part number on top of the chip. Make 2 backups,don`t flash anything yet
This is the dump of my bios. I don't know if I did it right!
I've already flashed...Attached FilesLast edited by ManuCE; 09-14-2021, 04:02 AM.
Originally posted by ManuCE View PostThis is the dump of my bios. I don't know if I did it right!
The bios chip is 4MB not 8 as i said at post #4 ,
it should say something similar to 25Q32 on topLast edited by SMDFlea; 09-14-2021, 05:03 AM.
Originally posted by SMDFlea View PostWrong chip,what you`ve posted is the USB3 firmware for the ASMedia IC .
The bios chip is next to the big square chip with 128 legs. The bios chip is 4MB not 8 as i said at post #4 ,
Originally posted by SMDFlea View PostyesAttached Files
