Lg oled65b6v
    Lg oled65b6v
    i was watching the TV when it turned itself off. On turning it back on the screen does not light up. The audio is OK. I have checked all the power supply output voltages 12v and 24v and these are OK.
    Could it be that the OLED panel has failed? Are there any checks i can do to work out if the panel has failed?
    Re: Lg oled65b6v
    dont touch any things... since your LG now working and have sound no error only screen black search here i dfid wrote many time how to send command IN_STOP to make hard reset for LG.
    since the screen black you may after send the command In_Stop send with urs original RC thr code 0431 the TV will goes to STB. plug iit out from wall for 1-2 minute and then turn on... hope yours screen come back..
    if not and before do in_stop while you hear sound plug it out from the wall.. insert air mouse or usb mouse ant any usb port... and a usb key on its root one file mpeg ( video ) and plug it in tv.... start playing with mouse while you plug it back to wall .. this will help if the tv in deep sleep ( save mode ) to wake it up. good luck
      Re: Lg oled65b6v
      Thanks for the reply. Imputing 0341 with TV remote but does not go to standby.
        Re: Lg oled65b6v
        input the code after you send in_stop
          Re: Lg oled65b6v
          Can you tell me how to input In_Stop? Thanks
