I modified a battery pack module controller to work on much bigger battery pack
But things did not go very well at first because the temperature sensor wire are very thin and very hard to clean the soldering joint hole I had use another board and attempt to repair this board later if needed for another project
Because the temperature sensor wires are very short and had to be made longer
which the second attempt when a lot better
This is for my Ksger t12 soldering iron station
The Kobolt battery pack charger was modified to charge this battery pack
( the charger case was used in another Ksger battery operated soldering station I put the charger controller board in a computer switching power supply case )
Here are some pictures below ( these pictures are to see if the battery pack module controller would work correctly or not with a bigger battery pack )
The charger does not take very long to charge this battery pack but it was about 80% charged
I will take more pictures tomorrow how the case looks
