Picked up this monitor last week, non-working. Date stamps show it was made around 2004.
There is a picture on-screen, I can see the desktop in very good light, but the backlight isn't coming on. It uses an external power supply (like laptop power brick), which is outputting the correct 12V.
Inside the case, the parts look like they would be used in laptops. Certainly, a search of the Samsung panel on google shows that it's been used in Dell laptops of that era (panel).
The inverter is an Emax PLCD2215202E, looks like it's been used in laptops as well. The connection from the mainboard to the inverter consists of 4 wires, on the red and black wires I'm seeing 5V and 12V, the other 2 wires up to 50mV, so presume these are signal wires, and the 5V and 12V are good.
I've uploaded a couple of pictures of the inverter board. The 2A fuse is ok. Are the 3 caps likely candidates for replacement here? The panel doesn't light up for an instant, so wondering if I should be looking at the panel/CCFLs for problems, or anything else I should rule out first?
