*FIXED* Suyama MJ7CNA Monitor - backlight kept turning off after a second!
    My mum had a problem with this second hand monitor. Its not a bad one, and didnt want to chuck it if it was repairable.
    The backlight would turn off after a second. The image was still there as could be seen by shining a torch close to the screen.
    I ruled out the backlights as theres 2 in there and would be too much of a coincidence if both had gone at the same time. Could'nt find any bad caps either, but did notice a kind of scorch mark in the middle of one of the toroids. So I looked underneath, and it looked like a dry solder. Resoldered it, and it now works fine!!! Yay!
    Hope this helps others who may have similar symptoms.
    Re: *FIXED* Suyama MJ7CNA Monitor - backlight kept turning off after a second!
    I cannot get the cabinet open Is it just to prise it appart after taking out 6 screws I do not have a manual Thank you Graham
      See if you can lift the front bezel a little,and gently pull ,I usually start at the top in the centre,and then if it gives you enough room to get a flat knife etc in the gap made, work your way around.
