Window XP Product Actvation Not Working
    I using this windows XP computer right now
    I am using My-Pal to get on the internet which it seem to work OK on most website
    I can not update internet explore on Microsoft website either ( I tried to install it from thumb drive but it gave a error message that it dose not support the version of internet explorer that I have )
    Which that part I do not care about one way or the other
    I guess I will have to active it by phone unless someone know another way to do this
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: Window XP Product Actvation Not Working
    I just use corporate editions for any remaining XP boxes. No activation.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      Where do I find a copy of this
      thanks
      9 PC LCD Monitor
      1 Dell Mother Board
        You got the wrong installer for Internet Explorer, very likely. Note that you can't use later than version 8. (IE8)
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        16 GB AData XPG Spectrix D41
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
          I have version 5 on it right now
          I tried install version 7 and version 8 no go with either one
          9 PC LCD Monitor
          1 Dell Mother Board
            thanks
            I can give you a copy of the media, but you'll have to scare up a VLK....they're out there, probably not too hard to find.
            Team : 49813
            Join in!!
            Team Stats
              Sam doesn't indicate whether it is a "beige box" or a "brand name" computer. In the latter case, hunting down XP install media from that manufacturer will usually eliminate the need for activation (I have a folder of various media that I use for machines, here).
              [This is a big advantage to sticking with mainstream hardware -- no need to EVER go on-line]
              In some cases, you have to trick the media (HP likes to try to tie their media to specific models) to running.
              You can also modify a retail ISO to convert it to a manufacturer specific issue.
              And, of course, you can always hunt down keys for XP on-line.
                You've got a point....but VLK/Corporate edition negates it all anyway....
                Just out of curiosity.....does an x86 VLK for XP work with an x64 corporate media? I don't have XP64 Corporate media, but I know there was an edition......so if I tracked down this media, would my x86 XP keys work on it?
                Team : 49813
                Join in!!
                Team Stats
                  I have looked for a recovery disk for this computer and not found one yet
                  IBM 8183
                  9 PC LCD Monitor
                  1 Dell Mother Board
                    Code:
                    t7jqm-cx6bd-v2ddv-qryvx-pprtb
                    (All caps)
                    "pokemon go... to hell!"
                    EOL it...
                    All style and no substance.
                    guilty,guilty,guilty,guilty!
                    guilty of being cheap-made!
                      Originally posted by kaboom View Post
                      Code:
                      (All caps)
                      Incorrect product key
                      9 PC LCD Monitor
                      1 Dell Mother Board
                        If it's a corporate key, you have to install using corporate media.
                        Team : 49813
                        Join in!!
                        Team Stats
                          What version of XP, look at system properties (right click My Computer, Properties) Post the first 8 digiits under Registered to:
                          XXXXX-YYY-*******-*****
                          Just post the X & Y
                          That key provided is for Pro-SP2-VLK
                            Originally posted by r_j View Post
                            what version of xp, look at system properties (right click my computer, properties) post the first 8 digiits under registered to:
                            Xxxxx-yyy-*******-*****
                            just post the x & y
                            76477-oem
                            9 PC LCD Monitor
                            1 Dell Mother Board
                              76477-oem
                              That is XP Home Royalty OEM
                              Did the PC have a label on it with the CD key?
                                Yes. I've never installed a VLK here (though see below) as I want the ability to expose a machine to the outside world (e.g., this one) even if I don't ever do it. Using the OEM "self-activating" media means a machine can't tattle on me as having done something "shady".
                                [The OEM media are mass produced so unlikely that the install disk for THIS machine was different from the install disk that I actually used]
                                No idea. I suspect it wouldn't. For the same reason that install media for (e.g.) Home and Pro versions aren't compatible.
                                I set up a "lab" for a local nonprofit and used VLKs for XP and Office version <mumble> -- but, those were "legally" issued by MS to the nonprofit (there is a place where you can request licenses for nonprofit use). Technically, the VLKs were authorized for 20 copies -- which I had to just make a note of as I was building the machines -- but I don't know if the machines check with each other to verify that count is never exceeded.
                                  Yes but it for a Windows XP professional which I do not have a copy but there are no device drivers for this version a least I have not found any
                                  I could not find an ISO version of it any way
                                  9 PC LCD Monitor
                                  1 Dell Mother Board
                                    IE 5 was never on XP. Are you sure you don't have windows 2000?
                                      That's what I was thinking....I thought IE6 came with XP.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                        He reported 76477-oem which is XP Home Royalty OEM, So something ain't right
