Hi, fixing tv's is my new hobby and I have this TCL LE32HDF3010 that turns on but has no backlight.
First I checked all the caps on the Cold side of the board cause that's one of the only things I know how to do so far lol. They're all fine to my knowledge. Then I opened up the screen so I could use my fancy new LED tester and all the LEDs are lighting up and all 3 LED strips are wired together straight into the power board (ES282C2). I'm assuming the LED tester showing that they're running at 60v means that's how much they require. The power board is only putting out 46v whether the LEDs are connected to it or not. Also when the TV is on standby the voltage stays at about 40v and I thought it was odd to be getting that much power on standby, but I don't know very much .
So I sat there for a few hours attempting to trace the 46v to a source thinking I could narrow it down to a component but I wouldn't dare cross into the Hot section of the board because I can't make out where AC ends and DC starts cause there's no obvious bridge rectifier.
I figured out that in a dark room the backlights do come on for a second only but not bright enough to see with the lights on. I measured the voltage while this happens and it goes up to OL first and then 80v, 70v, 60v, 46v over a couple seconds.
If I turn the tv on and have the LED tester powering the LED's instead of the power board, the tv seems to work as it should.
I could just spend $25 on a used board but I'd really like to get to the bottom of this if I can, and learn as much as I can in the process. Thanks for any help!
