Hey everyone!
Initially, my TV didn't want to start up sometimes and had to restart several times to have a picture and start up. One day it stopped completely and would not start since then. If I press the turn on button the blue led starts to light and after 30-60 secs (didn't measure it) it turns off completely. Except if I start it in service mode(plugging it in while holding input + vol-), because in this case it won't turn off unless I press the power button.
I started with observing the power board and everything seemed to be fine. I checked all the voltages on the connectors and everything was correct except the backlight enable pin. So I shorted the BL_EN with the PS_ON (booth 3.3 V logic if I remember correctly) and the backlight turned on without a problem.
I then moved to the main board. I touched an IC and the backlight suddenly started to turn on and off quickly (no picture still) and I thought maybe it's faulty or has contact problem. So I replaced it (IC9701) but the symptoms were the same as before. (Probably I opened the MOSFET with my finger due to electrostatic charge)
I still thought it was a mainboard problem, but I couldn't find a new mainboard for this TV. One day a similar (QPWBXF915WJN2) board appeared in Germany but not for this TV, it was for an LE542E. I checked that it uses the same T-CON board as my TV. The difference between these two are the chips. Mine uses ZR39691HGCG while the LE542E uses ZR39690HGCG. (FRC: ZR39300BGCG vs ZR39301BGCG) I think the only difference between the two are that the 39691 has 3D support which I frankly don't need.
So I thought it's not that expensive, and ordered it. After I installed it, the TV was capable of powering up and I could turn it on/off using the main power button but I still couldn't produce any sound. (I plugged in a PS4 and tried to rotate through the sources but no sound and no backlight) The FRC and CPU chips are hot with both mainboards. Sadly I don't have an oscilloscope to check if they send signal towards the T-CON board.
The T-CON board is dead cold with both motherboards.
So now I'm in bit of a trouble. I can't say for sure that the motherboard is fine, since the motherboard isn't for this TV. I think it should work with the same T-CON board, but it is possible that I'm missing something here and my TV won't power up with a LE542E motherboard even though all the connectors are the same.
My suspicion is that the T-CON board is dead and these mainboards have a check signal if the T-CON board is fine and powered up so the lack of this confirmation signal is causing the mainboards to not power up the TV properly. But frankly I'm only a mechanical engineer and my knowledge on TVs is limited.
So I ended up here hoping that someone could help me out.
Thanks for all your help in advance!
