Hi just visited a friend who has a problem with a samsung i have enclosed pictures i tried twisting the screen surround made no difference.I did try the tv on the wi console and it has sound the picture just has loads of lines on it etc on certain inputs you do get a white cloudy screen with times the lines get less and you can see the no signal box/menu/hdmi writing etc.I am thinking tab bond issue whats your thoughts.
Samsung LE40A65A1FXXA
Re: Samsung LE40A65A1FXXA
Defective LCD panel. may be possible to shim the tab bonds. I have one doing similar when very cold.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
cheers tom are the tabs on these top/bottom or side? just curiosity ive just asked my friend the back ground of the tv he got it from a mate it went like this when they was cleaning the screen so as you say probably fluid on tabs or the pcb to tabs? if on the bottom. tom in the past you recomended to me some solder braid from cpc you use can you send a link im just placing a order cheers again for your input.
Just been told by my friend they left the set on all night still had lines and bad picture, he switched the tv off to move it and then he switched it back on the pictures perfect? and hes been watching it for hours now with no issues at all.I will try the shims on the tab bonds and see what happens from cold i guess.
