Hp No Power Up Issue
    I am having and issue with two different Hp PC's. One is a core I5. The other has the AMD Vision four core cpu. When the power button is pushed these units will not power up. I have gotten these things to start working again by doing the following things. First unplug the A/C core. Then I disconnected both plugs from the PSU to the main board. I then held the power button down for a few seconds to discharge the MB caps. Then I pluged everything back in and the PC's booted as normal. Could this be caused by a low cmos battery? Both of the units are three years old or so.
    "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
    Mark Twain
    "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
    John Paul Jones
    There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
    Rod Serling
    Re: Hp No Power Up Issue
    Nope. The only thing that will happen if the CMOS battery goes flat is that it will start losing the date and time and other BIOS settings. It never stops the PC from POSTing or powering on (at least for 99.99999% of motherboards). It might be the PSUs. Or possibly something else with the motherboard.
      your a bit off with that number, a pretty large number of modern intel boards need the battery to start.
      that said, once it does start, you can check the battery voltage in the bios.
      it may not be acurate, but it will be enough - if the battery is under 2.5v in the bios it's done.
      infact under 2.9 and it's going fast.
        I haven't seen a board that won't POST without the battery installed - including plenty of Intel boards.
          What PSU's are in them?
            try some of the ATOM based boards.
              Huh, never seen this before. Well, Intel has done it again!
              What power supplies are in these? I think you should check the 5v standby voltage to see if it is good.
              Muh-soggy-knee
                I can't do anything right now. The PC is 85 miles away from me and I'm sick with the flu anyway. I need to be feeling better before I go down there and tackle her POS.
                Mark Twain
                John Paul Jones
                Rod Serling
