equivalent for HT3582DM
    looking for equivalent or better than HT3582DM . or somewhere i can get one in short time . https://html.alldatasheet.com/html-p.../HT3582DM.html
    Re: equivalent for HT3582DM
    Here is a website link that has a Reverse Engineered Schematics
    https://danyk.cz/reverz30_en.html
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      thanks ..
      i had already seen that and figured mine was same ic . one i have has chinese writing on the ic . it appears to be shorted .i did something silly and blew it up .
      i just need the ic so i can charge my torch batteries .
      another thing i know its badly made but actually worked fine until i blew it up .
        Where did you buy them from can you post a link to them
        9 PC LCD Monitor
        1 Dell Mother Board
          i haven't bought any .. i need to find them yet that can be delivered in short time like a day or even a week . most say around a month or 2 delivery
            Here is an alternative to repairing this unit
            I have used this type of charger and they work pretty good if can find one that is built very good
            https://www.aliexpress.com/item/2251...98515936%21sea
            Here where are you can find them at
            https://www.ebay.com/itm/16545799492...AAAOSwmdFiWNDT
            I was asking where did you buy the flashlight from
            9 PC LCD Monitor
            1 Dell Mother Board
              Estimated between Fri, Jun 10 and Mon, Jun 27
              that charger requires a holder . or add a socket to my one but i suppose a holder is cheaper
                what battery is in your light?
                infact show the light - i suspect i know the type
                  18650 battery . torch is xml-t6 ultrafire ..
                  now we have the unnecessary info out of the way does anyone know where i can get a chip in reasonable time .
                    no.
                    the reason for the "unnecessary info" is because i was thinking of alternative solutions.
                    i cant find your lamp model,
                    i assume it has a micro barrel connector on it going directly to the battery terminals though.
                      the battery is separate and looks like this .
                        6800mAh my ass, i'd love to throw that in my Li500 analyser
                        get a decent charger - they arent too expensive.
                          been looking for a decent charger and they cost a lot . thinking of getting a tp4056 module for now ..
                          i will let one of the people i work for buy me a nice one along with a bench power supply and battery spot welder . plus anything else needed for rebuilding battery packs properly .
                            what voltage is in the "charger" ?
                            if it's 5v then you could put a tp4056 inside it
                              i thought of buying a holder and module then using a usb charger i already have . costs less than £4 to get my torch batteries charging for now . then go for something big and fancy with digital readouts later on for sorting cells for rebuilding/repairing 80v packs .
                              i am sure i have plenty of components here to build a 4.2v charger circuit with led lights included but cant really be bothered . modules can be had for about £1.50 . it would possibly cost more using parts from my stock .
                                i can probably send you a module - i think i have some spare.
                                you have the holder already i presume?
                                  have just ordered a module and holder thanks .
                                    built it up earlier .. rough and ready and working fine . glued to nice lump of aluminium just in case anything gets hot .
                                      quick follow up ..5 chips arrived from china . first one charging at 4.3v . not happy so randomly picked another one 4.12v . i think that's near enough .
