dell latitude 5490 bios
    Hello great engineers. Please I need bios dump for dell latitude 5490
    Re: dell latitude 5490 bios
    The latitude 5590,5490 and 5290 use the same bios . Check post #10 .https://www.badcaps.net/forum/showthread.php?t=67599
      Pls if u have the password to extract the dell latitude 5590 share with me
        Post here lock bios
          Thank u so much, and may ur wisdom continue to grow as time passes by.
            Latitude 5490 EC Bios plz
            I need EC bios for Dell Latitude 5490
            LA-F401P Rev 2.0
            UT6 = 2 Mb
              Latitude 5490 LA-F401P ok
                need help DELL LATITUDE 5490
                HI I NEED BIOS DUMP FOR DELL LATITUDE 5490
                ddm70 la-f401p bios bin rev:3.0
                THANK U
                OKBALORD
                  Re: need help DELL LATITUDE 5490
                  Use the forum search "la-f401p" , bios already posted for you to try .
                    thank you but i tried all the bios in the forum and the result is no display!!!
                    OKBALORD
                      Post your original bios backup .
                        the problème that i do is that i dont make a backup i flacshed direct and clear the original tptally
                        OKBALORD
                          hello friend
                          try this one and let me know résult .
                          good luck
                            Originally posted by foulou0238 View Post
                            hello friend
                            good luck
                            TU BRO BUT NO POWER AT ALL
                            OKBALORD
                              Re: Latitude 5490 LA-F401P ok
                              Thank
                                need Bios and EC dump for Dell 5490
                                Hello, need Bios and EC dump for Dell 5490 (Compal LA-F401P rev. 3.0 / A02).
                                Thanks in advance.
                                  Re: need Bios and EC dump for Dell 5490
                                  Try this if not working post your old dump
                                  https://forum.laboneinside.com/viewtopic.php?t=7625
                                    try this ..
                                      Originally posted by basic View Post
                                      try this ..
                                      The bios is corrupt,its 12,288KB
                                        Please clean me region la:F401P
                                        bios works but the first screen comes up in 30 seconds
                                        Can you fix this
                                        model : Dell Latitude 5490
                                        bios :
