so 2305 working..
now i want you to remove the socket on the T-CON driver which it come from PWB 24V socket.. turn on and give notice on Audio optic lit red or not... give time 1 minute
Strange, usually I get 1v on the 24v rail (measured on power supply).
When 202 is unplugged, I get 0v
The fuse on the tcon (measured good) reads 1v on either side. I presumed it was the power supply sending that 1v, but it seems like it's being backfed somewhere on the tcon.
Yep, I can bridge the P201 pins 24 (drv_on) & 17 (stby) and confirmed the power supply outputs 24v (tcon/mb unplugged from power supply).
That signal is not getting sent from the mainboard.
Would you like me to bridge it while it's connected to the mainboard/tcon?
you can do it but only in this way... if pin 24 are drv_on trace the cable of it which it come from MB.. cut it in the middle then bridge pin 24 with stb put back socket 202.. and turn on and put your eyes on the screen and the audio optic if its turn red
BTW: of course we are talking on the bridge only at PWB side
