Lenovo M72e, Machine Type 3267, IH61I Bios
    Requesting
    Lenovo M72e
    Machine Type: 3267
    Board number: IH61I Rev 1.0 Bios
    Thank you
    Re: Lenovo M72e, Machine Type 3267, IH61I Bios
    Post your bios backup .
      Main and EC bios backup
        Try this and report back
          Much appreciated Servis Null but still no display.
            try this one. Bios version F4KT60A ,for Tiny (SFF)
              Originally posted by SMDFlea View Post
              try this one.
              With this one, the fan spins and stops continously every 2 seconds.
                Ok try these,make sure you flash both.These are verified working so if they don`t work for you the problem is somewhere else.
                  Thank you so much SMDFlea, these files worked!
                    Hi SMDFlea, you just saved me from buying another board, I flashed both chips on the board, same IH61I rev. 1.0.
                    This is a type 4004 machine and your files are working flawless.
                    Cheers.
                      Thats great, and thanks for the info that it also works on the type 4004 .
                        hi all,
                        how can i flash the bios with the *.bin file?
                        which program?
                        thx
                        greetings from germany
                            Is this bin file will work with Lenovo M72e, Machine Type 3598??
                              There are 3 different bios versions for the M72e models .Open your bios backup with a hex editor and search for these keywords to find which version you need
                              F1KT , F4KT , F9KT
                              ThinkCentre M72e (Ivy), ThinkCentre Edge 72 (Ivy) and Lenovo 62 is F1KT***
                              ThinkCentre M72e (Tiny) is F4KT***
                              ThinkCentre M72e (PCI) is F9KT***
                              The bios at post #8 is F4KT
                                Requesting
                                Lenovo M72e
                                Matchine type 3662
                                Board number: IH61M
                                  Originally posted by OziasAlfredo View Post
                                  Requesting
                                  Lenovo M72e
                                  Matchine type 3662
                                  Board number: IH61M
                                  i have moved your request to a new thread https://www.badcaps.net/forum/showthread.php?t=102526 ,i sent you a message
                                    Many Thanks its working
                                      Please need help to clear BIOS dump
                                      Attached
                                        Attached
                                        have you tried post # 8 ??
