Requesting HP ZBook 15u G3 6050A2892401-MB-A01 EC and Bios
    I have a HP ZBook 15u G3 board number 6050A2892401-MB-A01 that will not turn ON. I was able to read the main bios but the EC bios chip is completely unreadable.
    Does anyone have a matching file? Thank you
    Re: Requesting HP ZBook 15u G3 6050A2892401-MB-A01 EC Bios
    try..
    https://www.alisaler.com/hp-eliteboo...1-mb-a01-bios/
      Thanks but not working
        Post your main bios .
          Here is the main backup
            try..
              Originally posted by peste View Post
              try..
              Working...thank you so much!
                Which is the main bios chip? I mean the number of chip.
                Thanks.
                  I have made some mistakes. I got the laptop for free and there was a password in the bios. So I tried my luck. I bought a CH341A and don't ask how. But I accidentally read the IC chip W25Q128JVIQ and made a backup of it and tried to unlock it. Then I realized that the password is not saved on it. I also have a backup of that.
                  I SOMEHOW damaged the other bios chip. It can't be read or written.
                  I then bought the same defective laptop for $20.
                  But I realized that the motherboard is not the same. I also got confused with the chip. I don't remember if it's a W25Q128JVPQ or a W25Q128FVPQ.
                  My guess is a W25Q128JVPQ.
                  Now I have soldered the W25Q64JVIQ back on. And loaded the bios from the other defective laptop onto the W25Q128JVPQ and also soldered it on. Now I have the problem that the laptop doesn't start anymore. CAPS Lock is on.
                  If I remove the battery, the laptop turns on, has a black screen, and the fan spins.
                  Laptop: zBook 15u G3
                  Mainboard: 839235-601
                  Bios Chip: W25Q128JVPQ
                  If someone has the same laptop. Is the Bios chip correct?
                    Post bios backup and serial number.
                    Become a Badcaps supporter
                    Thanks to all supporters.
                      I have only the Bios Backup from the other Laptop.
                      My Mainboard: 839235-601
                      My Serial: 5CG8174XGV
                      The Laptop from the Backup has the Mainboard: 918325-601
                        Look on the motherboard for a part number similar or the same as 6050A2892401-MB-A01 ,post it.
                          HP ZBook 15u G3 Mobile Workstation
                            Hello my friend,
                            its 6050A2892401-MB-A01
                              SMDFlea commented
                              Editing a comment
                              Merged your posts with an existing thread topic
                            Can i use any Bios firmware that has the same motherboard?
                              SMDFlea commented
                              Editing a comment
                              If its an intel board not without cleaning the ME firmware first, and your DMI info will be messed up and you`ll have to enter it all again using HP`s shitty DMI tools (unless it does a bios recovery and restores it itself). Try the bios posted by hoaca388
                            Is it difficult or complicated to edit the DMI information? I am relatively familiar with software and everything. I can quickly familiarize myself with everything.
                            I also have an Intel. I'll try the BIOS above later. Thank you very much
                              SMDFlea commented
                              Editing a comment
                              The HP DMI tools are relatively easy to use once you get used to using them but if its the first time then it can be a real headache.
                            Do I need another program besides DMI Tools from HP?
