Dell inspiron 1564 6beeps then 5beeps
    Hi friends, I have dell inspiron 1564 DA0UM3MB8E0 REV:E REV:A00 PWB:5X2FJ UM6.the problem when plugged in and press power button turns on with 6beeps then followed by 5beeps then fan spins but no display.Anyone can help on this please
    Re: Dell inspiron 1564 6beeps then 5beeps
    Check the cmos battery voltage , take the hard drive out and see if it powers on. Try different memory . If none works it could be a bad gpu.
      thanks for the response i already done that replaced ram, replaced cmos battery but still the same issue, my mistake the model dell inspiron 1464 I3 CPu with no dedicated graphics
        Check display jack pin voltage if 3v present
          Where is display jack voltage located?
            Try check out this chart.. Maybe can help you.. TQ
              I reflowed the ATI chip the issue was gone and laptop boots fine, it's graphic issue.does anyone help me how to convert this from dis to uma or disable this ati chip?Please help
                need help please!can someone share how to convert this from dis to uma enable
                  post schematic here. i will try to help
                    Thanks for the response but i dont have schematic for this.can someone please share
                      Dell inspiron 1464/1564 cannot be convrerted from dis to uma-100% sure. So dont waste your time-either change the graphics chip or look for a new mb.
                        hi every one i have dell 1564 and this mother board have problem it is chip set if any one have uma conversion i need help please
                          Read post#11
