Hp 250 g6 csl50 la-e791p
    I have a hp 250
    when power the computer blink
    Caps lock blink 5 slow 3 fast
    I write the bios with dump and ene chip , but the same problem
    any suggestions
    Re: Hp 250 g6 csl50 la-e791p
    Originally posted by cacascacas View Post
    I have a hp 250
    any suggestions
    Hp 5 blink System bord Failure +19V 3/5V must be ok the Schematic is not available , what is the SIO chip check all pins EC Bios for Voltage test all colis Diode mode Ohms
      Hello
      The SIO chip is ene kb9022q
        Hello
        Cannot find the data sheet for KB9022Q
          Hello
          I find the pdf of kb9022q.
          can you help me
            Check all this pins on SIO be careful not to short pins , when you get this sine # it’s high low depending on the platform MB +3V volts when you press the power button will go to 0V and come back or 0V will rise to +3V volts check all pins one by one
            125 VCC
            37 EC RST#
            6 SLP S3#
            19 AC PRESENT
            123 SLP S4#
            122 PWTN OUT#
            110 AC IN
            112 EC ON
            114 ON/OFF BTN#
            115 LID SW#
            116 SUSP#
            100 RSMRST #
            101 EC LID OUT#
              hello , did any one find the solution of this :
                Check all ram pins under a microscope
