I need help determining what this component is called? Also, where the best place to purchase them would be?
Need help with determining what this component is?
Re: Need help with determining what this component is?
This will get you close, https://www.digikey.com/products/en/...=1&pageSize=25
you will need the diameter, height & lead spacing to get closer
The originals had a "Ripple Current @ Low Frequency" of 2.04~2.49, so I suspect any of the replacements should be okLast edited by R_J; 05-01-2020, 12:07 PM.
The thermistor vendor is Uppermost Electronic Industries. Inrush thermistors are sort of like fuses in the sense that they don't blow like that on their own. There must have been a short circuit "downstream" from them.PeteS in CA
