Dell p93g Inspiron 5482 2-in-1
    Can someone help me
    BOARD ID is :BUCKY BENSOLO WHL CNL MB TVMHG$CA 17859-1
    the unit turns on for a second then turn off . I'm looking for some dump so i can try if this is a bios issue .
    here is my dump from the unit :
    https://drive.google.com/file/d/1P4z...ew?usp=sharing
    Last edited by SMDFlea; 09-18-2021, 02:09 PM. Reason: Added "Inspiron 5482 2-in-1"
    Re: Dell p93g
    Try..DMI+KEYWIN
    421000-427FEF
      Re: Dell p93g
      I have same issue , have you got the solution ???
        Re: Dell p93g
        make a backup of the bios, check it with the HxD program and try the bios from post # 2 ... if it doesn't work, post the backup.
          Re: Dell p93g
          I have this same problem, the laptop goes off after few seconds. When I tried the BIOS file on Post # 2 of "Peste" the motherboard stop turning off, but the fan does not spin & the AMP meter shows absolute "0" amp & The WHITE LED stay on. I am assuming that this is the BOIS problem. I am attaching my original BIOS for this motherboard 17859-1., kindly if someone can fix this problem of ours. Thanks in advance.
            Re: Dell p93g
            You assume right,as your bios backup is for an Inspiron 5481 .Try the attached new bios .
            Inspiron 5481
              Re: Dell p93g Inspiron 5482 2-in-1
              Thank you so very much "SMDFlea"., tomorrow first thing will try it & surely inform you about the outcome.... really appreciate.
                "SMDFlea" EXPERT you are I must say!!! Works 100% fine & no problems, all problems resolved, thank you & thank you.....
                  the same problem give me ok bios
                    Hello everyone
                    i also have the same issue
                    with this dell .."
                    i uploaded my backup original please help..
                      I have tried the files from SMDflea
                      same results ---- light on ..fan spins ... PSU goes up to 0.79Amps then back to 001Amps with no display.
                      I discovered the CPU gets a Temperature Spike super hot for 2-3sec then off (when tested with no heatsink on) but even with a heatsink and thermal paste it takes the same amount of time to cut off without posting.
                        The bios at post #6 is for the Inspiron 5481 as i said in the post. What model number is your laptop ? ,according to your service tag you have a 5482 ,try the bios at post #2
                          Hi and thanks for the reply.
                          its dell inspiron 5482 service tag : 3YN04P2
                            I tried it (The file on Post 2) same results switch on goes to about 0.79A for 3-4 Seconds then back to standby at 0.01Amp
                              It worked with the attached file but I had to leave it for a few minutes while I thought its on standby on 0.03amps, I came back it was on.
                                but posting is delayed by approximately 40seconds
                                  Clean the ME firmware
                                    Hello everyone
                                    with this dell .."
                                    someone please help fix the ME region.
                                      my 1st attempt was never successful I think I did something wrong.
                                        Here`s the ME Cleaning guide
                                        Follow section D4 titled: D4. CSME 11 - 15 & CSTXE 3 - 4
                                        https://winraid.level1techs.com/t/gu...lization/31277
                                        MEAnalyzer https://github.com/platomav/MEAnalyz...253.0_r262.rar
                                        Attached is ME firmware,already renamed to ME Sub Partition.bin (from 12.0.7.1122_CON_LP_C_PRD_RGN.bin) , and FIT 12
                                        Try it ,just follow the guide carefully. When you build the FW and get the outimage.bin open it with MEAnalyzer it should say configured
