Hi.
I have a Sony KD-55X8507C on the mending table today.
It appears completely dead, no status LED's lighting up. Even though it's acting completely dead, the power supply is running and the heatsinks on the main ASIC's do heat up, so it's just not starting properly.
This thread has been a lot of help since someone posted an excerpt from a schematic that contains the correct LED driver chip. without that pinout, anyone's guess
The power supply has two boost converters, each run 5 strings of LED's. All LED strings i tested to have a Vf of 87V@1mA, so they are all good.
All DC voltages looks OK. The supply for the LCD boost converter is 61V. The booster is NOT running. I tried pulling BL_EN and DC_DIM to 3.3V to enable the booster. The signals get all the way to the LED driver (CXA3854) pin 5 and 11 and it has the prerequisite 12V supply on pin 24 as well.
I tested all FET's, diodes etc in the booster. All seems good.
Nothing looks, burned, only the PCB around the two FET's is slightly discoloured.
I have no gate pulses on pin 26 on both the driver chips.
So this suggests dead chips i guess, but why would both die at the same time?
Any suggestions what to check before i order some new chips?
Thanks in advance!
// Per.
Thanks in advance!
// Per.
