Hey folks. I am trying to repair this TV and don't have any standby output (5V) on the power supply DPS-286AP to the main board. I have replaced IC7905, R7918, R7914, and D7908 as to Shopjimmy repair kit and I still don't have any standby output (5V). Any help would be greatly appreciated.
Sharp LC-46SB57UN no power
Re: Sharp LC-46SB57UN no power
This one is tough to work on due to the heatsink.
What DCV do you have measure right at the two legs of the main filter cap in the primary side? You will have to do the measurement on the bottom side of the board.
I assume the fuse have been checked already.Never stop learning
Originally posted by budm View PostThis one is tough to work on due to the heatsink.
Check the fusible resistor for feeding the B+ to the SMPS IC (P/N of the IC?).
Check the snubber diode, the secondary side diode for the STBY P.S.
Check the DCV on the startup caps in the primary side, measure right at the two legs of the cap, do not use chassis as the GND ref for the meter.Never stop learning
Fusible resistor original was 2.1 ohms and replaced with 5.6 ohm resistor (Shopjimmy repair kit)
Snubber diode .230 slightly going up
I've checked the ESR on C7918 and got 5.4 1uF 100V which I believe is high. Didn't check the voltage yet, but I'll be changing that cap And get you the voltages.
I would replace both of the startup caps at the same time.Never stop learning
Originally posted by fixertech View PostI have problems with R7914 resistor, I check and is open , I change it, but it burns twice , any idea or help finding the problem?
the new resistor is 2.2 Ohms 5 %Never stop learning
Correction, is your IC TNY264? If it is, then it will pin 6 and GND.
https://www.badcaps.net/forum/showth...656#post688656Never stop learning
Sorry, Typo, it is pin 5 the Drain pin.Never stop learning
No follow up NUTIN2LUZ? Well anyways I have a different problem. My fuse blew and I had to remove the heat shield. Under the heat shield I have a toasted capacitor. I have no idea what the value used to be and I can't find any diagrams online. C7816. At this point I have to guess what the value is. That capacitor and the fuse seem to be the only problems.
That looks to be snubber cap, typical value will be 220 ~ 330 pf 2KVNever stop learning
I looked up online "snubber capacitor" and it says there is suppose to be a resistor in series with it, no resistor. It does have a diode in parallel with it and it has a diode and transistor in series with it. My first thought was a surge protector but why is it in parallel with a diode, that does not seem like a surge protector. Any ways I may have a board coming to me where I will be able to see what the part is. I have offered someone to fix there board for shipping cost just so I can see what the original part is. So I am doing someone a favor and getting what I need at the same time. I will know in 3 to 5 days.
Not all snubber circuit will have resistor in series, for example snubber caps C7822, 7824 for the MOSFET Q7805/7808 are connected in parallel with the Source and Darin pin of the MOSFET's.
Cannot tell more until I see the bottom side of the board. Is your board exactly the same model and revision as OP?
is that the MOSFET or Diode next to that burnt cap?
Looking at OP pictures: https://www.badcaps.net/forum/attach...8&d=1426262140
That C7816 is the snumber cap for the diode D7806, the cap is connected in parallel with Anode and Cathode of the Diode.Last edited by budm; 09-09-2018, 12:58 PM.Never stop learning
