Hello, I have a Sharp LC- 58Q620U 58" LED 4K TV.
When you initially plug the TV into the 120V outlet, I get the initial standby red LED light. After you press the power button the red LED goes out and no other lights come. There is no backlight flash, nor image on screen. No audio with HDMI source plugged in, nor does my laptop detect another monitor plugged in. T-con board makes a clicking sound with or without LVDS cables hookup or off.
My first thought was that it had a faulty PSU. Reading voltages, I was getting a swinging voltages from the DC output from the bridge rectifier onward.
Replaced the PSU with a brand new unit. Getting very similar symptoms.
PSU# RSAG7.820.8349/ROH (REPLACED WITH NEW, HAD SAME SYMPTOMS)
MAINBOARD # RSAG7.820.8353/ROH
( Readings with ** are voltages that are swinging or fluctuating every second or so)
Bridge Rectifier- 120.8v ac / 161.1v dc – 167.7v dc **
Cap1 (C810) – 349.1v | Cap2 (C811) – 349.2v
Before Pressing Power Button ( Standby Light LED ON )
BSW .039v | TSW 0v (pin1)
PWM .030v | PWM 0v
GND 0v | VAMP 19.85v Falling
GND 0v | VAMP 19.9v Falling
NC 0.041v | GND 0v
GND 0v | STB 0.073v
12V 9.04v - 9.30v ** | 12V 9.05v to 9.3v **
3D5G 0v | 12V 9.04v - 9.29v **
After Pressing Power Button ( Standby OFF - No Other LEDS Lit )
BSW 4.667v - 4.679v ** | TSW .004v (pin1)
PWM 2.025v - 2.054** | PWM 0v
GND 0v | VAMP 19.97v - 20.16v **
GND 0v | VAMP 19.98v - 20.15v **
NC .110v -.152v ** | GND 0v
GND 0v | STB 2.708v - 2.712v **
12V 9.88v - 12.14v ** | 12V 10.2v - 12.14v **
3D5G 0v | 12V 10.18v - 12.14v **
I have not been able to dig up a schematic or service manual for the TV or Boards
Hopefully, I have given enough information for it to be useful.
EDIT - Failed to mention, this model does not have any volume or channel buttons on the unit itself. Only a single power / rocker button on the bottom right of TV.
PWM .030v | PWM 0v
NC 0.041v | GND 0v
GND 0v | STB 0.073v
