Focusrite Saffire Pro 40 re-cap
    Re: Focusrite Saffire Pro 40 re-cap
    Finally got around to taking the top off one of my Saffire 40's, so here's a hopefully-clear-enough photo of the bottom.
    Since all those resistors are toasted on yours, there's a pretty good chance the MOSFET is also gone, as is the PWM controller.
    No idea what the stock PWM controller was, but as i mentioned, i managed to find a nearly-pin-compatible one, in the Diodes Incorporated AP3105NAKTR-G1.
    The photo seems to be from the other Saffire 40's power supply which was ok. If memory serves, in the first one, with the new PWM controller, i removed the 100K R12.
      Thank you
        U1 is a LeadTrend part on the one i have here for repair, markings are JP 35 but i can't find it exactly.... LD7535 is the exact part.
        LD7535ABL is P1 35,
        LD7535BL is YP 35,
        and more QP 35, WP 35, S1 35, XP 35A, G1 35, and so on.
        but i can't find JP 35 anywhere, it is for sure LeadTrend LD7535 part. i might change it for a P1 35 and see what happens.
          Thanks for the update. Assuming one can find a datasheet for that chip, i would expect the differences (if any) to be somewhat visible.
            Markings are on page 2 of the datasheet. First letter is the week code, while the "P 35" indicates the part number, looks like.
            The -A version seems to be spec'd for only 21V for the overvoltage protection trip point, while the non-A is rated for up to 28V. Installing an -A could be pushing your luck for no good reason.
              yea, main issue now is the part is only available in china so maybe the AP3105NAKTR-G1 is our only hope, or the new PSU fullcompas sells. idk
              if i find a decent supplier and i don't forget, i'll post it here
                The part i used isn't "the only hope", it just happened to be the cheapest pin-compatible device that one of my preferred suppliers had in stock at the time. And since i couldn't know what the stock part was, it was a bit of a crapshoot, but it worked.
                  Hi.
                  I decided to post here because it's about Focusrite PSU.
                  I own 4 octopres MKII. They remained unused for a year. This week I had a recording gig and took them to do it. Out of 4, two units presented the same problem when turned on. The clock front panel remained dead with all LEDs unlit. No word clock out or in.
                  What I found is that the PSU might be the origin of the problem. I disconected the 5v supply cable from the main board and checked with a multimeter. I found that the 51v pin measured around 58v steady, but the other voltages were varying all over the place. The 15v and -15v went from 12.1 to 13.4, back to 12 and started all over again. The 5v pin went from 0 to 2.5 to 3.2 to 4v back to 0 and so on.
                  I think this is not normal and should get all the voltages steady as the 51v pin, tough it's a little higher, 58.2v.
                  I thought some capacitor was the cause and changed all the electrolytics after the transformer secondary. I replaced the caps with the same value but not with the same voltages for all of them. Regarding the 470uf caps, 3 are 63v, one is 50v and the other is 16v. The 2200uf is 16v and the other 100uf are 100v as the originals.
                  All replaced, nothing changed.
                  So I checked all resistors in the back and all are ok.
                  Regarding the ICs and transistor, I have only checked the Mosfet which seems to be ok.
                  So my question is... what might be the origin of the problem? I believe this varying voltages are not normal and this is the reason why the clock panel does not light.
                  Thanks in advance.
                    The small cap C5? is most important. It's 10-22uF 50V I am guessing.
                    Be careful to discharge ALL the capacitors before plugging in the connector.
                    Focusrite PSUI001007 Power Supply PCB for Scarlett 18i20, Saffire, OctoPre MkII, RedNet 1. Gee it's got cheap electrolytic capacitors used in it.
                      Originally posted by Khron View Post
                      I got this lovely and versatile audio interface a couple years back, for some multitrack recording with my (former) band, and as a "foundation" for my (future?) home-studio.
                      A while back, i decided to "pop the hood" and check out the insides. The PSU made me cringe - C(r)apXon It puts out 5v for the digital/logic stuff, +/-15v for the analog stages, and 51v for the phantom-power. I haven't yet replaced the mains filter cap (since i figured it's not under THAT much strain, plus i don't have a suitably-sized one in stock... for now ).
                      Well, you can't blame Focusrite. Everything that is made in China these days has to use parts that are also made in China, unless requested specifically by who ordered the production. It's one of them govt's rules.
                      With that being said, I wasn't surprised at all when I peeked inside Liquid Saffire 56 to find ChangXin caps in the audio path and in the PSU section.
                      What surprised me is when I had to service a $4000 SSL channel strip rack unit 5 years ago. For power, they use a cheap low quality switching PSU that cost $1 a piece if you buy in bulk (which they did of course), and they put a price tag of 150 pounds before tax and shipping for it on their online store. What a rip off!
                      I revived the mic pre by replacing the blown out fuse and PWM IC (it's a TOP PWM IC, I forgot the series but it has a TO-2XX transistor package if I'm not mistaken), also recapped it with Chemicon KY. Took 3 days to disassemble and assemble including a 24 hour test period in which I abused the thing just to see if the PSU would hold up in performance and stability. I charged $75 for service labor and parts, which the client happily paid me. The preamp is still running to this day.
                        Hi newbie here! First time poster:
                        Can this PSU board of my beloved Liquid 56 be resurrected
                        It's toast, unfortunately, or do I have to order a new PSU?
                          Hi, did you manage to solve it? I have the same problem!
                          I can't find another one to replace this U1, I searched on google and there is no datasheet talking about this U1 (VP35)
                          Originally posted by bfpgio View Post
                          Here it is cleaned
                          what is written on that U1? Mine was damaged and I can't read what it says
                          Last edited by SMDFlea; 05-15-2023, 02:39 PM. Reason: Merged three seperate posts into one
                            LD7535ABL is P1 35,
                            LD7535BL is YP 35,
                            I'm also looking for this U1, could I find a component that can replace it? I can't find this JP35
                              Did you managed to get a replacement psu and if so did that work?
                              I have exactly the same problem with my saffire pro 40, exectly the same pattern of frying ;D
