mytv te32
    mytv te32
    hi all, I have a tv that remains fixed in stand-by, sw mp022-jd power supply would seem ok. i think about a firmware problem, the mather board is a cv306h-f. the eeprom memory 25q32fvsic.
    I would need a firmware via usb, or a bios for eeprom. thanks to all greetings zac.
    Re: mytv te32
    Post your non-working firmware dump here, I'll try to fix it.
      Re: mytv te32
      thanks for the answer, the discharge from the eeprom? in what format?
        Re: mytv te32
        Originally posted by zac View Post
        thanks for the answer, the discharge from the eeprom? In what format?
        .bin
          Re: mytv te32
          Unsolder 25q32fvsic, read its contents (firmware) on the programmer, save and upload this file in BIN format.
            Re: mytv te32
            here I am ... hello LOTAS, sorry for the huge delay.
              Re: mytv te32
              Try it, don't be surprised that the dump size has become smaller.
                Re: mytv te32
                hello lotas ...it doesn't open with win.ra ... it tells me damaged archive
                  Re: mytv te32
                  Update winrar or use 7-zip
                    Re: mytv te32
                    Update WinRar
                      Re: mytv te32
                      eeprom file working at the first try .. perfect thanks lotas .. the tv had corrupted file, probable forced shutdowns ... question if the same defect occurs again, can I put the .bin file you restored on usb and boot directly from the tv?
                        Re: mytv te32
                          Re: mytv te32
                          Thank you lotas it works perfectly.
