What is the best way to clean old relays?
    I've got an old Motorola R2200 service monitor which gotten wonky, because the previous owner had it sit in a damp basement. Almost all basements are damp around here. Of course it uses an unobtainable relay. Most of the 80s stuff doesn't use sealed relays, rather have a see through plastic on top that pops off.
    Problem is that this relay needs to be cleaned. However the relay is so small that my burnishing tools do not fit. Same problem with other old gear that use these small miniature relays with the clear top cover.
    What's everyone's mini relay cleaning secret?
    IPO, Deoxit etc?
    Re: What is the best way to clean old relays?
    Dose relay have anything about it that is special about it
    If not why not replace it with the same specifications or better and mount where you have room
    Are talking about the degaussing relay for the screen
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      replace it
        crocus cloth and switch cleaner
          again, these relays can't be replaced because they were obsolete long time ago. And yes, it is about room constraints / location of the original residing relay. There is an option of relocating, but you really don't want to do that either when RF is in the game and the leads would be way too long.
            pictures or part numbers would help
              Aromat AC8043.1408
                I have used some P600 sand paper cut into a thin strip and sometimes I will fold it to clean both contacts. You can find very fine paper 1000 ~ 4000 grit
                  i cant find any reference to that relay other than search hits on this thread!
                  got any pictures?
                    The dilemma is that this relay is under the card slots. Couldn't be any worse than that.
                      it looks similar to this one, but I cant make out the coil voltage on yours. https://www.ebay.com/itm/AROMAT-S-SE...-/131730385563
                      The coil resistance of 720Ω seems to be 12v coil, the 5v one has a 130Ω coil
                      The Panasonic S series might be have a replacement
                        My relay is 720Ω... There are 2 relays in there I noticed in the service manual. I guess, I have to find now the other one. The AG number on the relay is different on ebay. Anyway if I could find a sealed relay replacement, that would be the best idea.
                          I would say you have read the numbers wrong and it says something like Aromat AQ3043.1408
                          The drawing on the relay shows a "4 form A" configuration, the last two terminals are empty.
                          Panasonic S4EB-12V would be a replacement example if the pin spacing is correct:
                          https://eu.mouser.com/ProductDetail/...uUfO%2Fw%3D%3D
                            Thanks Per! The first 2 letters AC was wrong, but it’s an AG as far as I can see. The second letter is not a Q and not a C.
                              An old telecom tech told me to use printer paper to clean contacts and not remove all the plating.
                              If you can't get strips in the relay, then it's going to have to be a spray job.
                              I'm using PPE based stuff like DeOxit unless it's switching HV or mains.
                                I personally use the cheapest nastiest kind of toilet paper, the one that scratches your bum, lol. Then a burst of duster to blow away the fragments that have fallen inside and it's all good.
                                A working TV? How boring!
                                  Toilet paper like in this commercial?
                                  https://www.youtube.com/watch?v=tTvjRyv0c5M
                                    Yeah... kinda what I've been doing all along... IPO and Deoxit for those little buggers that no one can clean. Most of them switch RF (RX/TX relay) or band pass (filter board). I haven't found anything better than IPO and Deoxit D100 combo yet.
