Sony Hcd-Fxg9k No Power
    Hi folks, i have a sony home theater here thats with no power issue for a very long time, probably due to lightning strike. I have sorted out primary and fuse no longer blows out. This unit has 2 STR IC, one is STRF6168 and STRV153. Both has been replaced, electrolytic caps has been replaced, a few smd diodes replaced and resistors replaced. The problem now is, on VCC of STRV153, voltage are fluctuating between 12v to 15v up and down. Theres no voltages at all on any of the output pins. I have checked all the smd components, all seems to be reading accurately. But i know there IS something thats preventing the STRF6168 to start up. VCC on STRF6168 is 2v. Any kind souls that has repaired this unit before care to shed some light?
    Re: Sony Hcd-Fxg9k No Power
    Is Sony schematic diagram parts stated in service manual is accurate? Just wondering. I noticed a diode on the board and the diode stated on the service manual is not same even though parts location number is same
      Anyone? Im going bonkers with this power supply When i remove the zener diode D924 which is 24v, voltage no longer fluctuating. Its stable at 13v. Am i missing something here?
      Or i have changed the wrong zener diodes on D923 (10V), D924 (24V), D925 (5.1V) and D926 (10V)?? I followed the voltage rating according to service manual. I also noticed certain components thats on the service manual doesnt exist on the board, so i assume this board being used on several models. So i suspect the ZD could be wrong. Even after removing that diode, theres no signs of any voltages on the output.
        Nobody?
          Which voltage is now stable? the output 13.3 on the secondary? or the voltage on Q921?
          Why did you replace the zener diodes? where they shorted? or did you just guess they were bad?
          Have you checked the caps such as C922, C924
          Do you have any of the 4 secondary voltages on T902?
          If IC921 was bad, is R927 1Ω ok?
            Primary side, all components tested, all good. Only standby section failing. Yes the diodes failed, so i replaced them according to service manual but i made a mistake, i forgot to see the number on the original diodes to make sure its same.
              IC901, C908, Q901, IC921, C924, Q921, PC902, PC901, PC903 has been replaced, still no luck. Theres no whatsoever voltages on secondary side of the transformer. I replaced those diodes because they were bad. STRV153 was exploded, and R925 was open. voltage on Q921 seems stable at 13v upon removing D924.
