I have a RX-A2A that doesn't do anything besides stuck with WN9711 Update. Any ideas I can get pass this screen?
Yamaha RX-A2A WN9711 Update
Re: Yamaha RX-A2A WN9711 Update
Looks like there is a TTL port on the lower left. Hook up to it and see what’s going on in there. I suppose you can’t do the reset procedure? You also could put the latest firmware on a USB stick and try to update it. Maybe someone tried to do an update, but then pulled the stick out or turned the unit off.Last edited by CapLeaker; 11-18-2022, 07:03 PM.
The error would suggest the wireless lan had a problem, Try putting the firmware on a usb stick as suggested, or try connecting a network cable?
See if this procedure works with this model:Last edited by R_J; 11-19-2022, 01:37 PM.
Originally posted by Plurxtc1 View PostRepair is completed. There was a port on the board where I jumper the pins that allowed me to access the settings to complete to the update.Listening to Drab Majesty, Chime, Deftones, and other Rushdown Label artists. Professional tech.
Do you remember what pins it was please?
Here are the instructions. Took me a while to hunt it down. Should help for RX-V4A, TSR-400, RX-V6A, TSR-700, and RX-A2A showing a WN9711 update. Gotta program the EEPROM.Listening to Drab Majesty, Chime, Deftones, and other Rushdown Label artists. Professional tech.
will this work with yamaha rxa4a reading internal error? trying to locate the land but the guts look way different than the posted pics
everytime i try to update firmware via usb the end result is error 100000 (one attempt yielded error 400000), and then internal error (once was wn9711)
thx
I have a TSR-700 with internal error. Made the jumper and the message 'modeldesterror' appears.
When I press scene 1 or 2, I get only this
No model name to select.
The serial number is there and works, but not the models.
What do you sugest?
