#1 |
City & State: Valbonne, 06
My Country: France
![]() Please post any suggestions and corrections to the discussion thread: https://badcaps.net/forum/showthread.php?t=103527
For additional information on SPI ROM, BIOS, EC, Intel ME, etc., please read: https://github.com/ISpillMyDrink/UEFI-Repair-Guide/wiki Table of Contents: Code:
1. How to dump and flash 1.1. BIOS 1.1.1. Programmers 1.1.1.1. TL866II 1.1.1.2. T56 1.1.1.3. RT809F 1.1.1.4. RT809H 1.1.1.5. EZP2019 1.1.1.6. CH341A 1.1.2. Adapters 1.2. EC 1.2.1. Programmers 1.2.1.1. SVOD3 1.2.1.2. SVOD4 1.2.1.3. Vertyanov 1.2.1.4. RT809H 1.2.1.5. RT809F 1.2.1.6. T56 1.2.1.7. TL866II 1.2.2. Adapters 1.2.3. Automatic flashing 2. How to clean ME/TXE region 3. Password removal by laptop brand 3.1. Acer 3.2. Apple 3.2.1. 2011 and older 3.2.2. 2012 to 2017 3.2.3. 2018 to 2020 (T2) 3.2.4. 2020 and newer (M1) 3.3. Asus 3.4. Dell 3.5. Fujitsu-Siemens 3.6. HP 3.7. Lenovo ThinkPad 3.7.1. Password ROM bypass (2012 and older) 3.7.2. DXE password bypass driver injection (2012-2018) 3.7.3. Flashing EC (2019-*) 3.8. Microsoft Surface 3.9. Panasonic, and some other standard AMI implementation 3.10. Toshiba 3.10.1. Consumer 3.10.2. Business 4. DMI editing by brand 4.1. AMI-based standard BIOS (SuperMicro…) 4.2. Acer 4.3. Apple 4.4. Asus 4.5. HP 4.6. Intel Network Adapters 4.7. Lenovo 5. Clearing NVRAM 6. Finding bios update packages 6.1. Major brands 6.1.2. Acer 6.1.3. Apple 6.1.4. Asus 6.1.5. Dell 6.1.6. Dynabook (Formerly Toshiba) 6.1.7. Fujitsu 6.1.8. HP 6.1.9. Lenovo 6.1.10. Microsoft 6.1.11. Samsung 6.2. Other brands 6.2.1. Clevo 6.2.2. Gigabyte 6.2.3. Haier 6.2.4. Medion 6.2.5. MSI 6.2.6. Schenker 7. Extracting BIOS/EC firmware from update packages 7.1. Desktops 7.2. Laptops 7.2.1. Asus 7.2.2. HP 7.2.3. Lenovo 7.2.4. Samsung
OpenBoardView — https://github.com/OpenBoardView/OpenBoardView Last edited by SMDFlea; 08-12-2023 at 04:11 PM.. |
#2 |
My Country: France
![]() 1. How to dump and flash
1.1. BIOS BIOS can be updated from software using the manufacturer's tool. It can also often be dumped from software (although not really reliable). However, if you need to re-flash the BIOS because the computer does not boot and BIOS recovery procedure does not work, you need an external programmer. Likewise, if you want to modify the BIOS to remove a password, it must be done with an external programmer. When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical. Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly. Additionally, please read the FAQ at: https://www.badcaps.net/forum/showthread.php?t=98665 1.1.1. Programmers TL866II is arguably the most reliable and easy to use programmer while still being relatively cheap. If you also need eMMC support, consider T56 or RT809H If you need LCD monitor In-System Programming through VGA port, consider RT809F or RT809H. 1.1.1.1. TL866II Supports I2C, SPI, LPC, FWH, parallel. Support list: http://www.autoelectric.cn/MiniPro/TL866II_List.txt 1.1.1.2. T56 Supports I2C, SPI, LPC, FWH, parallel, eMMC. Support list: http://www.xgecu.com/MiniPro/T56_List.txt 1.1.1.3. RT809F Supports I2C, SPI, LPC, FWH, VGA ISP. Parallel interfaces support requires PEB-1 extension board and can be troublesome. Support list: https://www.hklrf.com/24download/img/RT809F-List2.txt Software: http://doc.ifix.net.cn/download/2017266 1.1.1.4. RT809H Supports I2C, SPI, LPC, FWH, parallel, eMMC, VGA ISP. Support list: https://hklrf.com/24download/img/RT809H-List2.txt Software: http://doc.ifix.net.cn/download/2017266 1.1.1.5. EZP2019 Supports I2C (24-series), SPI (25-series), 93-series. Support list: https://www.hklrf.com/24download/img/EZP2019-List.txt 1.1.1.6. CH341A Supports I2C (24-series), SPI (25-series). This programmer is not recommended but it is the cheapest programmer available. It has several shortcomings:
Available software include: NeoProgrammer, Colibri, AsProgrammer, Flashrom… Read the guide there: https://www.win-raid.com/t4175f16-GU...rogrammer.html If you have a black PCB, it is very likely that it needs to be modified for 3V operation instead of 5V. Failing to do so could damage the ROM IC. Watch the instructions there: https://www.youtube.com/watch?v=-ln3VIZKKaE https://www.youtube.com/watch?v=HwnzzF645hA 1.1.2. Adapters It is possible to use clips on SOIC-8 ICs to avoid desoldering, however it is *very unreliable* and will often lead to an empty or corrupt dump. Avoid whenever possible. It is recommended to desolder the chip and use an adapter board or socket. They exist for all sorts of packages: SOIC-8 200mil, SOIC-8 150mil, SOIC-16, WSON-8 8x6mm, WSON-8 6x5mm, USON-8 4x3mm, PLCC-32, TSSOP-48… Most common packages for the BIOS SPI ROM on modern boards are SOIC-8 200mil and WSON-8 8x6mm. Desktop boards sometimes use DIP-8 which can be inserted directly into the programmer. Desktop boards before around 2005 used PLCC-32 (which can use a LPC, FWH or parallel bus), even older boards (in the 90s or older) used DIP-32. MacBook Pro 15"/17" boards before 2015, MacBook Pro 13" non-Retina and MacBook air before 2011 use SOIC-8 200mil MacBook Air and MacBook Pro 13" Retina boards between 2011 and 2015 use WSON-8 8x6mm. Apple boards from 2015 to 2017 use WSON-8 6x5mm. Apple boards from 2018 onwards use USON-8 4x3mm for T2/M1 ROM. 1.2. EC Dumping and flashing EC often requires a dedicated EC programmer. Some EC can be flashed with regular SPI ROM programmers. List of EC that may require programming: https://www.badcaps.net/forum/showthread.php?t=66963 1.2.1. Programmers 1.2.1.1. SVOD3 Code:
ENE ITE Nuvoton SMSC Code:
ENE ITE Nuvoton SMSC Support list: https://hklrf.com/24download/img/RT809H-List2.txt Code:
ENE KB9010 KB9012 KB9016 KB9018 KB9022 KB9028 ITE IT8386E IT8580E IT8585E IT8586E IT8587E IT8595E IT8985E IT8987E IT8996E Nuvoton NPCE288N NPCE388N SMSC MEC1653 MEC1650 MEC1633 MEC1609 MEC1619 MEC1618 MEC5035 MEC5045 MEC5055 MEC5075 MEC5085 Not a dedicated EC programmer, standalone programmer supports EC SPI and JTAG interfaces only. PEB-1 extension board supports ITE interface. Support list: https://www.hklrf.com/24download/img/RT809F-List2.txt Code:
ENE KB9010 KB9012 KB9016 KB9018 KB9022 KB9028 ITE (requires PEB-1 extension board) IT8580 IT8585 IT8586 IT8587 IT8985 IT8595 IT8987 IT8996E SMSC MEC1653 MEC1650 MEC1633 MEC1609 MEC1619 MEC1618 MEC5035 MEC5045 MEC5055 MEC5075 MEC5085 Not a dedicated EC programmer, supports EC SPI interface only. Support list: http://www.xgecu.com/MiniPro/T56_List.txt Code:
ENE KB9010 KB9012 KB9016 KB9018 KB9022 Not a dedicated EC programmer, supports EC SPI interface only. Support list: http://www.autoelectric.cn/MiniPro/TL866II_List.txt Code:
ENE KB9010 KB9012 KB9016 KB9018 KB9022 Adapter boards exist for some programmers, chip must be (partially) soldered on the adapter board, then the adapter board is connected to the programmer to be flashed. In most cases, EC can also be programmed in-system through the keyboard connector. Adapter for the programmer to keyboard connector is required, as well as correct cable (keyboard connectors can have different number of pins and different pitch). Pinout of the keyboard connector matching the EC programming interface must be known and set up in the programmer software. 1.2.3. Automatic flashing Some platforms can automatically flash a blank EC from the image stored in an external SPI ROM alongside the main BIOS when power is first applied. This assumes that there is no other issue on the board. Platform with automatic flashing:
#3 |
My Country: France
![]() 2. How to clean ME/TXE region
Cleaning ME/TXE region is required after replacing the PCH or the SoC. Sometimes the ME region gets corrupted on its own and it also required cleaning. Cleaning ME/TXE region consists in replacing the existing ME/TXE region in the BIOS dump by a fresh, non-paired one, retaining the manufacturer's configuration. Symptoms when ME region cleaning may be required include:
Refer to: https://www.badcaps.net/forum/showthread.php?t=88533 and https://winraid.level1techs.com/t/gu...lization/31277 . Do not use use Intel ME/TXE Injector/Easy Clean ME or similar tools: they do not retain the manufacturer's configuration and can cause subsequent problems. Last edited by SMDFlea; 08-12-2023 at 04:19 PM.. Reason: Edited winraid link |
#4 |
My Country: France
![]() 3. Password removal by laptop brand
DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices. The information given here is for personal use only, ie. you accidentally set a password on your own machine, you forgot the password you set a long time ago or you mistyped the password when setting it and cannot get in again. Note that a device bought locked might also have been stolen if the previous owner cannot give the correct password. This is especially common with business-grade equipment (Lenovo ThinkPad…) that employees sneak out or do not return. 3.1. Acer If you enter empty password 3 times, the BIOS gives you a code. 8-digit answer generators are easily found on the web. For 10 digits, see here: https://www.badcaps.net/forum/showthread.php?t=84084 3.2. Apple 3.2.1. 2011 and older For 2011 and older machines, changing RAM configuration and performing 3× PRAM reset can clear the password. Password can also be extracted from BIOS dump. 3.2.2. 2012 to 2017 For 2012 to 2017 machines, BIOS must be edited and reflashed to clear the password. There are 2 methods for this:
3.2.3. 2018 to 2020 (T2) For 2018 to 2020 machines with T2, T2 DFU restore with Apple Configurator 2 can clear the EFI password, however it will not remove the iCloud account. iCloud account is bound to the T2 of the machine on Apple servers and cannot be permanently unbound except by Apple. Methods to bypass activation screen thanks to checkm8 exploit exist. 3.2.4. 2020 and newer (M1) For 2020 and newer machines with M1, no publicly known bypass method has been confirmed yet. 3.3. Asus A lot of Asus machines use a standard AMI implementation, and BIOS password can be decoded or cleared from AMITSESetup NVRAM variable. See: https://www.badcaps.net/forum/showpo...55&postcount=2 Master codes for some dates also exist. 3.4. Dell Dell laptops store the password in EC. However, some generators exist depending on the code suffix. See: https://beta.bios-pw.org/ 3.5. Fujitsu-Siemens See: https://www.badcaps.net/forum/showthread.php?t=79974 3.6. HP BIOS password is stored in NVRAM in the BIOS. BIOS editing and re-flashing is required. You can use the automatic unlocker at: https://www.badcaps.net/forum/showthread.php?t=98539 Another tool that may also work: https://www.badcaps.net/forum/showthread.php?t=103184 3.7. Lenovo ThinkPad There are mainly 3 methods to unlock ThinkPads and some other Lenovo laptops depending on the generation. 3.7.1. Password ROM bypass (2012 and older) Most ThinkPads from 2012 and older (3rd gen Intel and older) use a 24-series dedicated password ROM. It can often be bypassed during boot by shorting the SDA and SCL pins together. Other times, flashing the ROM may be required. 3.7.2. DXE password bypass driver injection (2012-2018) For newer machines (2012-2018, 4th to 8th gen Intel), the password itself is stored in the EC. BIOS must be modified and re-flashed to insert a special driver that will allow bypassing the BIOS password. Refer to https://www.badcaps.net/forum/showthread.php?t=87588 and https://www.badcaps.net/forum/showthread.php?t=81573 3.7.3. Flashing EC (2019-*) On the latest generations of ThinkPads, the security issue that allowed to inject the DXE driver and bypass the password does not exist anymore. The password is still stored inside the EC, in a write-only region. However, it appears that dumping the EC with a dedicated programmer, erasing it and flashing back can actually clear the password. See: https://www.badcaps.net/forum/showth...t=95736&page=5 3.8. Microsoft Surface Surface Pro 3 passwords are stored in AMITSESetup NVRAM variable and can be decoded from the BIOS dump without any need to re-flash. See: https://www.badcaps.net/forum/showpo...&postcount=139 Surface Pro 4 and newer cannot be decoded, password must be removed from dump and re-flashed. 3.9. Panasonic, and some other standard AMI implementation Password often can be decoded from the BIOS dump, see: https://www.badcaps.net/forum/showthread.php?t=102275 Otherwise, AMITSESetup variable can be cleared from the BIOS dump and re-flashed. 3.10. Toshiba 3.10.1. Consumer A lot of Toshiba consumer laptops have a jumper on the motherboard that needs to be shorted before boot to clear the password. 3.10.2. Business Most Toshiba business laptops do not have a jumper, and the password is stored inside a protected region of the EC. See affected models: https://www.badcaps.net/forum/showpo...2&postcount=19 Either you need a donor EC without password, or you need to unlock through challenge-response. Response generator is not available publicly, however, some generous people may be able to generate a response for you. Ask in this thread: https://www.badcaps.net/forum/showthread.php?t=79489 Laptop must not be rebooted, the challenge will change. Last edited by SMDFlea; 02-13-2022 at 03:55 PM.. |
#5 |
My Country: France
![]() 4. DMI editing by brand
DMI editing can be required to restore model number and serial number after flashing a blank dump or rebrand a machine after board replacement. 4.1. AMI-based standard BIOS (SuperMicro…) See: https://www.badcaps.net/forum/showpo...2&postcount=18 4.2. Acer See: https://www.badcaps.net/forum/showthread.php?t=103301 4.3. Apple For 2017 and older machines, serial number is stored in Fsys store of BIOS and can be edited with hexadecimal editor. Fsys checksum needs to be fixed afterwards Search for "ssn", edit the serial number, save, open dump in UEFITool, go to the Fsys store and write down the suggested checksum in the panel on the right. Checksum is 4 bytes at the end of the Fsys store, between one zone of 0x00 either Gaid or another zone of 0xFF, it must be written in reverse order (so last 2 characters from UEFITool must be written first). See: https://www.youtube.com/watch?v=poA8HByYqTM 4.4. Asus With these tools you can add DMI information, add a MAC address to older generation Asus boards and fix the keyboard backlight not working on newer generation boards.
4.5. HP See: https://www.badcaps.net/forum/showthread.php?t=69204 4.6. Intel Network Adapters Not specific to a board manufacturer but rather to the Ethernet controller on the board. If you want to fix the MAC address of some Intel controllers, you can use eeupdate: https://www.badcaps.net/forum/showpo...8&postcount=17 4.7. Lenovo Lenovo IdeaPad C340-15IML/FLEX-15IML/S340-15IML/S340-15IML Touch/S340-14IML Lenovo XiaoXin-15IML 2019/XiaoXin-14IML 2019: https://www.badcaps.net/forum/showthread.php?t=98038 LVAR: https://www.badcaps.net/forum/showth...64#post1133564 Last edited by piernov; 05-17-2022 at 02:32 AM.. |
#6 |
My Country: France
![]() 5. Clearing NVRAM
Clearing NVRAM manually from the BIOS can help if NVRAM variables become corrupt and POST does not finish successfully, or BIOS freezes before boot, or when entering Setup. Actual process may vary between BIOSes, but blanking the first VSS store inside the first NVRAM area can be enough. |
#7 |
My Country: France
![]() 6. Finding bios update packages
In order to fix a corrupt BIOS or EC firmware, it may be necessary to find and use an image provided by the manufacturer. Manufacturers rarely provide an image ready to flash, but rather an update file that may contain extra data or missing part of the full image. Note that using a clean BIOS like this will lose DMI info. All of the major brands provide an official support page.If your laptop or PC originated in your own country go to the country specific support page or region. 6.1. Major brands The current Top 10 brands,listed in alphabetical order. 6.1.2. Acer https://www.acer.com/ Enter the SNID at the downloads/drivers page. 6.1.3. Apple 6.1.4. Asus https://www.asus.com/support/ Laptop - Look for a barcode or QR code on the motherboard for a model number to find the bios version the board came with and search at the support site with that model number. See: [TUTORIAL] fix asus bios with bios from asus web support https://www.badcaps.net/forum/showthread.php?t=96604 6.1.5. Dell https://www.dell.com/support/home/en-uk?app=drivers Enter the service tag.Also look at the configuration that the laptop shipped with - the OS, AMT enabled or disabled,Corporate or consumer ME firmware. 6.1.6. Dynabook (Formerly Toshiba) https://dynabook.com/global/en/index.html Dynabook has dropped support for many toshiba models.If no bios update is found with the serial number search with the short product number instead. 6.1.7. Fujitsu https://www.fujitsu.com/global/support/ 6.1.8. HP https://support.hp.com See: [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/showthread.php?t=122195 6.1.9. Lenovo https://support.lenovo.com Enter the serial number and/or model type. 6.1.10. Microsoft Some but not all updates can be found inside the MSI installer drivers package See: https://badcaps.net/forum/showpost.p...25&postcount=2 6.1.11. Samsung Samsung do not provide bios downloads at their support pages. See: ID Samsung bios from dump and download the official update https://badcaps.net/forum/showthread.php?t=88206 6.2. Other brands This list will not be kept in alphabetical order. 6.2.1. Clevo No bios downloads at official support page. See: https://badcaps.net/forum/showpost.p...89&postcount=2 log in with - username repo . password repo 6.2.2. Gigabyte https://www.gigabyte.com/Support 6.2.3. Intel 6.2.4. Medion https://www.medion.com/gb/service/ Enter the product number or MSN.Some updates can be found by searching the Medion forums. To find bios updates via google search put an x at the end of the model number instead of the last number,followed by the word bios. 6.2.5. MSI https://www.msi.com/support 6.2.6. Schenker & XMG https://download.schenker-tech.de/ 6.2.7. Panasonic https://pc-dl.panasonic.co.jp/itn/index.html https://panasonic.net/cns/pc/ 6.2.8. NEC https://www.nec.com/en/global/support/index.html 6.2.9. Huawei https://consumer.huawei.com/en/search/? Search by laptop model number then click on support tab. 6.2.10. ASRock https://www.asrock.com/support/ 6.2.11. ECS Elitegroup https://www.ecs.com.tw/en/download-center Last edited by SMDFlea; 09-07-2023 at 02:49 AM.. Reason: sync |
#8 |
My Country: France
![]() 7. Extracting BIOS/EC firmware from update packages
In order to fix a corrupt BIOS or EC firmware, it may be necessary to use an image provided by the manufacturer. Manufacturers rarely provide an image ready to flash, but rather an update file that may contain extra data or missing part of the full image. Note that using a clean BIOS like this will lose DMI info. BIOSUtilities: https://github.com/platomav/BIOSUtilities
7.1. Desktops Retail motherboards can have a full BIOS image or only an update. Pre-built desktops will have DMI info, and mostly only a BIOS update. The full BIOS image may be packed into an UEFI Update Capsule. UEFITool with recognize the UEFI Update Capsule and allow you to extract the body in order to obtain the raw BIOS image. 7.2. Laptops For laptops, the manufacturer rarely provide the full BIOS image. The usual procedure is to extract the BIOS region, and if provided the ME region, from the update package, and insert them back into the original dump using Intel FITC. If ME region is not provided, it can be cleaned with one from the win-raid repository at the same time. 7.2.1. Acer and other Insyde-based UEFI See: https://github.com/ISpillMyDrink/UEF...-Tool-(H2OFFT) 7.2.2. Asus See: https://www.badcaps.net/forum/showthread.php?t=96604 The full BIOS image or update may be packed into an UEFI Update Capsule. UEFITool with recognize the UEFI Update Capsule and allow you to extract the body in order to obtain the raw BIOS image. 7.2.3. Dell AFUDELL: https://www.badcaps.net/forum/showthread.php?t=115830 7.2.4. HP See: https://www.badcaps.net/forum/showthread.php?t=121948 7.2.5. Lenovo Phoenix TDK: https://www.badcaps.net/forum/showthread.php?t=80861 Last edited by SMDFlea; 08-18-2023 at 03:44 AM.. |
Thread Tools | |
Display Modes | |
