Hi:
I am trying to rescue this Yamaha amplifier. It turns on, does some relé clics and then switwes off.
Following up the service manual, I've entered into diagnosis mode (Fm + 8 + switch on during 3 secs to avoid protection). It shows the error shown in one of the pictures. If I am not misunderstood it might be a power supply issue.
These are the voltages I am getting in CB272 connector (page 33)
Amplifier just plugged in:
S10 -> 9.7-10.3V (quite unstable voltage)
PRY -> -122mV
E -> -108mV
PDET -> 5.06V
+5M -> 5.10V
/RES -> 4.99V
As soon as I switch on........voltages decreases dramatically (3 rele clicks and let's start again).
S10 -> 8.85V
PDET -> 4.02V
+5M -> 4.03V
/RES -> 3.76V
I've checked the 2 boards that make the power supply unit. All seems to be correct at component level......but I guess it's obvious that might be not true, right? or there is something outside that drains so much current? (I don't think so as the voltages in standby mode "dance" quite a lot.
Any guidance is more than welcome.
PRY -> -122mV
E -> -108mV
PDET -> 5.06V
+5M -> 5.10V
/RES -> 4.99V
S10 -> 8.85V
PDET -> 4.02V
+5M -> 4.03V
/RES -> 3.76V
