Seasonic Platinum 860W No Fan Spin
    Hello
    I am a novice here but electronics enthusiast and general all round tinker.
    I have a Seasonic Platinum Series 860W PSU which does not turn on my PC. I get no fan spin and I have used the jump start method with the PSU out of the case and it doesn't turn on either. I believe this PSU doesn't need a load to begin working.
    I didn't see any bulging caps, burnt areas or burnt smell from the PSU.
    This is the same PSU as in this review: https://www.anandtech.com/show/5464/...-series-860w/4
    I have gone as much as using a screwdriver to discharge the capacitors (The 2 big brown ones) and then check the continuity on the fuse which shows as working (basically I get a bleep)
    I have access to a Kaiweets HT118A multimeter and a Pinecil soldering iron but how would I go about diagnosing the issue and what should my next steps be please?
    Re: Seasonic Platinum 860W No Fan Spin
    I probed +5VSB Purple cable with the PSU switched ON it reads 5.109V
    Additionally the Green PS_ON# wire with the PSU switched ON or OFF reads 3.230V
    No other wires are giving an voltage readings.
    HTH
      well thats good, standby is running.
      the 3,2v is from a pullup resistor - connect PS_ON to ground and it should start up the main section.
        Cross-posted https://www.eevblog.com/forum/beginn...s-not-turn-on/
        Too bad that guy didn't finish his schematic of the little side board. It's in Photoshop and I couldn't open it in Gimp. Or know the IC markings.
          I believe, its the same just different pcb color
