I bought on ebay an old Viz Triple Supplyst WP708. It's a bench power supply that also has limited voltage/current measuring capabilities.
It has 2 separate input/outputs, left & right. Everything on the right side works fine, the panel lights up, measures voltage & current correctly and the outputs are fine as well.
The left side outputs fine but the display does not work. I cannot check if it also measures fine. All connections seem ok, nothing looks disconnected or obviously busted. I looked for service manuals etc. but could not find any.
Any suggestions on how to troubleshoot? Where to start looking and suggestions on the likely culprit? Of course it would be great if someone had a manual.
In the attachments a front view of the panel (found the pic as I had taken it apart already) and a view of the problem board.
Thanks!
Antonio
Thanks!
Antonio
