#281 |
City & State: Lancs
My Country: England
I'm a: Hobbyist Tech
#282 |
City & State: london
My Country: uk
![]() it has to be there for the use cases that require it
#283 |
Meow Meow MEOW!
City & State: USA 🇺🇸
My Country: United States
Line Voltage: 120VAC 60hz
I'm a: Hardcore Geek
![]() Not true. MDM can still have Activation lock to the company email. Changing the serial will solve this issue and remove the lock for good. Even with iBridge 6+
MEOWING IN THE IMPOSSIBLE UNIVERSE! |
#284 |
My Country: uk
![]() right activation lock is based on email - be it personal or company
mdm lock is based on user profiles defined by company therefore you can't be mdm locked on a wiped computer since there is no os with profiles installed on it. if the activation lock email is the company email it doesn't make it a mdm lock. |
#285 |
City & State: haifa
My Country: israel
#286 |
City & State: Lagos
My Country: Nigeria
#287 |
City & State: haifa
My Country: israel
#288 |
Banned
City & State: Planet EARTH
My Country: Pakistan
Line Voltage: Very High ;)
#289 |
Meow Meow MEOW!
![]() Bypass method is not permanent why would anyone want to do that when changing the serial is 100% never coming back even if you DFU restore it?
Also to answer the other guy when he changes the serial it gives activation error, this means it’s iCloud locked and not MDM lock which means the T2 chip is the culprit, MDM locks do not use the T2 to communicate to verify. It goes like this Apple Server checks in these steps. 1. Apple server checks Serial number , if it kicks back as MDM it follows up with two scenarios, you either get into Os Install or you get the company email lock. 2. Apple server checks T2 chip serial after step 1. So if step one is a serial that is changed and then checks to see if the T2 chip is assigned correctly, which in return will give Activation Server Error messages. So in theory if you change the serial of an MDM device to new serial then you sign into your device with your iCloud after OS install and say you DFU reset it, that serial is now assigned to your iCloud with the T2 chip until you remove it. Hope this helps |
#290 |
City & State: Mos
My Country: España
![]() So,
Changing serial method will work on any T2 chip model, and sets it as a new device( any resets and updates will work as expected)? And what happened if you register 2 different Iclouds with the same serial number? ![]() |
#291 |
Meow Meow MEOW!
![]() Original first iCloud will always kick back. No matter what you do, the first registered iCloud will always come back first. Meaning it needs to be removed. The second iCloud will not even exist, only when you use the device in of itself.
#292 |
City & State: Mos
My Country: España
![]() Many thanks for reply, seems logic, i will try and see what happened.
About T2 chip in a Macmini for exemple, is possible to remove Icloud with the serial method? Thanks for help |
#293 |
City & State: UK
My Country: UK
![]() Hello
I reset the Macbook air 3 2o 2o comes out of the ground (bridge6) and activated icloud. If I flash the T2 chip with Unlock firmware with soldering, will it help to lower the bridge and bypass icloud activation? |
#294 |
City & State: Odessa
My Country: Ukraine
#295 |
City & State: UK
My Country: UK
#296 |
City & State: Mos
My Country: España
![]() Hi, just someone who could ask this question:
Its possible to unlock an Imac or a Macmini with T2 chip and an icloud activation lock with the serial hardware method? This item will remain as new, no locks , no icloud even with DFU mode resets? The only condition is the ibridge version as explained? Many thanks |
#297 |
City & State: Lancs
My Country: England
![]() This was discussed a while back and I actually bought one to try out.
But sadly, there doesn't appear to be any purple mode software that works with Macs. |
#298 |
City & State: Da Nang
My Country: Viet Nam
Line Voltage: 220VAC 50Hz
![]() warn someone buying a new mina tool. Apple did something to T2 and it doesn't work anymore
#299 |
City & State: Kiev
My Country: Ukraine
![]() Hi! my t2 chip transplant experiment failed. I successfully soldered the t2 chip but my board most likely has an underestimated resistance PP1V1_S3. This piece of shit, that I bought on ebay turned on black screen, after 5 times gomg and apple, before replayse t2 chip, after i have cycle dinamic voltage on PP5V_G3S. FUCKING CALCULATOR! I think i have bad cpu on this board to. Who can measure resistanse of PP1V1_S3?
#300 | |
City & State: Barcelona
My Country: Spain
![]() Quote:
Thread Tools | |
Display Modes | |
