T2 Chip Programmer Tool
This topic is closed.
  • JOHNLAG7
    • Nov 2014
    • 19
    • Greece
    #381
    Re: T2 Chip Programmer Tool
    Also T2 chip has 1 generation and 2 generation:
    A1989, A1990, A1932, A2141, A2179, A2251 use 1st generation T2 chip.
    A2159 ,A2289 ,MAC MINI A1993 use 2st generation T2 chip.
    • gugbobgug
      • May 2022
      • 14
      • Georgia
      #382
      Originally posted by JOHNLAG7
      Right if replace T2 can unlock the device but have in mind There are two types of T2 capacity: 1GB and 2GB
      T2 chip with 1GB capacity can control 128GB, 256GB, 512GB NAND;
      2GB capacity T2 chip can control 1TB, 2TB, 4TB NAND.
      So when 128GB, 256GB or 512GB NAND can use 1gb T2 For 1TB, 2TB or 4TB NAND,T2 chip must be 2GB.
      i know this
      • gugbobgug
        • May 2022
        • 14
        • Georgia
        #383
        yes it is right
        • gugbobgug
          • May 2022
          • 14
          • Georgia
          #384
          and friend i am interesting
          is there any option read and program this big T2 chip ?
          • ugamazing
            • Jun 2013
            • 165
            • usa
            #385
            No way to read/program T2 so far.
            • bb1
              • Oct 2022
              • 1
              • United Kingdom
              #386
              Originally posted by Stephen
              Mina did this because you had a special someone in the thread tell them so they had to create a code to stop this since you know…people don't want people to have nice things lol. I'm not worried about it. Our software is half way there.
              hey @stephen, just wondering how the completion of the software is going.
              • kevingill
                • Jun 2013
                • 152
                • England
                #387
                https://cdn.badcaps-static.com/pdfs/...6bdb9f3b72.pdf
                This is a useful read to better understand how the T2 works.
                • kevingill
                  • Jun 2013
                  • 152
                  • England
                  #388
                  Just found something interesting.
                  If you have an external disk with a MACOS installation (not an installer), you can boot from this if you hold CMD-R for a minute whilst it boots. You can release CMD-R once the loading bar appears. This will boot the recovery from the external disk instead of downloading it. I used Catalina, but others may work.
                  Once at the language selection, you can press CMD-T to bring up a Terminal.
                  • Reda123456
                    hi
                    • Jan 2022
                    • 88
                    • iraq
                    #389
                    hello is there a way to remove the entire mdm from MacBook Pro (13-inch, 2017, Four Thunderbolt 3 Ports)
                    model a1707 emc 3164
                    • ethiogsm
                      Banned
                      • Mar 2021
                      • 10
                      • ethiopia
                      #390
                      Cool try this with Mojave and no activation at all
                      • heatorious
                        • Apr 2020
                        • 2
                        Yes this can be done. Post your file
                          • 20544
                          Off-topic . Post your request in an A1707 EMC 3164 thread https://www.badcaps.net/forum/showth...light=emc+3164
                          • luca_v3r
                            • Nov 2022
                            • 6
                            • Italia
                            #393
                            Hi to all.
                            Sorry for my bad english.
                            I read all of 20th pages, and I want to thanks all.
                            I have an A2179 MBA with activation lock.
                            I have also the macbook password but the system said that I enter incorrect password too much time, an I can't use this method for bypass activation lock.
                            Moreover if I can find the complete email address of icloud I can retrieve the password.
                            What can I do? I have the new bridge.
                            I can boot with CMD+R and macOs hdd?
                            I don't be able to boot up with macOs external hdd.
                            Tks so much.
                            • luca_v3r
                              • Nov 2022
                              • 6
                              • Italia
                              #394
                              This can be able to bypass activation lock in my A2179 MBA, and boots up from external drive?
                              Have you use a usb-c hub, right? Or usb-c ssd directly?
                              • kevingill
                                • Jun 2013
                                • 152
                                • England
                                #395
                                I booted from a USB external MACOS installation (I used micro SD card in a USB C adapter), but it only allows you to access a terminal.
                                I don't know how to activate from the terminal, but others may know how this can be done.
                                • luca_v3r
                                  • Nov 2022
                                  • 6
                                  • Italia
                                  #396
                                  Originally posted by Timp74
                                  On a icloud locked a2179, I found the user's email in plain text using checkra1n and running the "strings" command on the NVRAM file in /var/private/db. I think that was the file and location.. Unsurprisingly the user didn't reply to my email or iMessage about unlocking..
                                  I have an A2179 MBA 2020 Activation locked, and I wanto to find the full iCloud email, because I know the previous owner.
                                  How I can find this information?
                                  • luca_v3r
                                    • Nov 2022
                                    • 6
                                    • Italia
                                    #397
                                    In my case, I've reset the mac and I don't have the recovery installed, so when I press CMD+R with usb Hdd with Catalina Os attached at MBA, going out only the world with wifi "choose network" request, I think for download internet recovery.
                                    • kevingill
                                      • Jun 2013
                                      • 152
                                      • England
                                      #398
                                      One of the more recent updates has removed the choice to select the language before checking for activation lock. It's best not to reset or the method I described will never work.
                                      • .::iRizwan::.
                                        Banned
                                        • Apr 2016
                                        • 63
                                        • Pakistan
                                        #399
                                        You can find only if not erased and have old BridgeOS.
                                        • luca_v3r
                                          • Nov 2022
                                          • 6
                                          • Italia
                                          #400
                                          ok, thanks for yours response.
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • baletak
                                            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
                                            by baletak
                                            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
                                            I have updated laptop model number.
                                            1) I did not find the way to update laptop serial number - I have this one.
                                            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
                                            Hope to find someone to help me with this as I am hitting dead end at the moment.
                                            Many thanks
                                            Miro
                                            05-23-2025, 01:21 AM
                                            How to add chip support to NeoProgrammer software for the CH341A Programmer
                                            by SMDFlea
                                            Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                            and once you do find them there`s a few crucial steps missing.
                                            Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                            Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                            After adding the chip save the xml file and copy it to the root directory of the...
                                            05-26-2024, 07:15 AM
                                            Common SPI bios chip programming Questions and Answers
                                            by SMDFlea
                                            Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                                            A: If you can`t read from it how do you expect to write to it ?.
                                            Q: Why is my bios chip unreadable ?.
                                            A: The programmer is faulty or has a worn or broken zif socket.
                                            The USB cable is frayed,connector pins worn or some other physical damage.
                                            Not enough amperage or voltage to power the programmer properly.
                                            Bad...
                                            09-02-2021, 04:40 PM
                                          • BMCappelletti
                                            Asus Chromebox CN62 - wrong chip put on BIOS reader
                                            by BMCappelletti
                                            Long story short:
                                            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                            - gave the computer to his son a couple years later
                                            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                            (seems like the story was not that short)
                                            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                            01-08-2025, 07:27 PM
