List of pin compatible pwm/supervisor PSU ICs
This is a sticky topic.
    This is my list of PSU ic pwm/supervisor pin to pin compatible. At least proven work for me..
    1. HY510N <=> WT7510 <=> ST9S313 <=> PS113 <=>RT7501
    2. TOP258 <=> TNY27x/TNY28x
    3. PS223 <=> WT7527 <=> DWA106
    4. PS229 <=> WT7525 DIP 14.
    5. WT7520 <=> EST7502
    6. TL494 <=> KA7500
    7. 2005AZ <=> ATE7520 <=> LPG899 <=> WT7520 <=> ATX2005 <=> SDC2005 <=> CG8010 <=> EST7502 <=> SR6110B
    8. WT7525 N161 <=> DWA105 N161
    I do hope anyone can add more in this list..
    i do need alot wt7525 n161, but i can't found it in my country. and if i ordered from ebay, it's so expensive. $10 each..
    i've read in forum, that wt7525 n161 is replaceable with DWA105 n161.
    That's great, because DWA105 is alot cheaper.
    but i confuse because there's no DWA series ic datasheet that i can find, so i cannot make sure this is really compatible.
    That anyone can find about DWA105 n161 datasheet?
    or anyone can suggest another ic that can replace wt7525 n161?
    Last edited by Per Hansson; 12-07-2019, 04:47 AM. Reason: Updating post with new models 6 > 8 and updated pos. 3
    Re: List of pin compatible pwm/supervisor PSU ICs
    Tl494 <---> ka7500
    PeteS in CA
      some addition
        addition for number 3.
        Update:
        i found a DWA105 N161 from old delta psu, tested with xigmatek nrp502, and this little thing works flawlessly as replacement.
        so, as an addition..
          I updated the OP with the new additions, very nice work!
            Know of anything compatible with a DNA1005A ?
              Unfortunately, i didn't not find any datasheet about it. so it must be done with trial and error. Maybe, just maybe, dwa105n161/wt7525n161 will work as replacement.
                Does this help ?
                  I'm very sorry, i can't precisely predict what is each pin function base on that schematic..
                    k thanks for looking into it.
                      Back in 1998-2001 when I worked for Delta, DNA1001 and DNA1002 were proprietary custom ICs. DNA1005A may be as well.
                      PeteS in CA
                        I believe you may be right about that.
                          I know this post if pretty old, but has been helpful to me.
                          same as TPS3510, TPS3511, LP7510
                            Please help Can you replace top256pn by top258gn
                              Yes, you can, the difference in power.
                                Let's make this thread sticky
                                  Done
                                    Thank you!
                                      I don't know if these are completely same but I've noticed their datasheets are identical(copy-paste) - HY510N and EST7610. I have also compared HY510N and WT751002 datasheets and found that the only difference are PDON_N pin Voltages: 2.0V/0.8V on HY vs 2.4V/1.2V on WT.
                                      It looks to me like either companies behind these have some agreements or they literally steal from each other.
                                      https://z3d9b7u8.stackpathcdn.com/pd...0N-HawYang.pdf
                                      https://z3d9b7u8.stackpathcdn.com/pd...ST7610_EST.pdf
