Please need unlock 830 g8
    HP elitebook x360 830 g8
    hi i have HP elitebook x360 830 g8 with password in bios
    can you help me remove it
    Last edited by SMDFlea; 03-26-2023, 02:41 PM. Reason: Deleted attachment due to low server space, March 2023
      Re: HP elitebook x360 830 g8
      Did you try this : https://www.badcaps.net/forum/showthread.php?t=98539
        missing file destination argument !
          Call HP support
          Become a Badcaps supporter
          Thanks to all supporters.
            Re: Please need unlock 830 g8
            Thank you, I returned the device to the customer without solving the problem
              [ATTACH]271019[/ATTACH
              pls remove password
                    Please help
                      please help
                      try
                        Originally posted by miansh621 View Post
                        try
                        thanks but computrace still on
                          Hello! I would like help in deleting the bios password of Hp Elitebook X360830 G8! Thanks
                          Last edited by SMDFlea; 03-26-2023, 02:42 PM. Reason: Deleted attachment due to low server space, March 2023
                            "Hello! I would like help in deleting the bios password of Hp Elitebook X360830 G8! Thanks"
                            Try it now
                              Professional work, thank you!!!
                                I can't lock the BIOS, what could be the reason? Please help, thank you.
                                  Restore Securriti Setting to Factory Dafaults, cannot be executed, there is a password
                                    Hi! The unlock file you sent back works fine, I can enter the bios, everything can be set. However, I have an administrator password. After turning on the machine, it indicates manufacture programming mode. I wanted to close the bios, but as you can see in the picture, it is not possible. Can you help me with that?
                                      Read post 15 hoaca388 suggestion. Might need to reflash BIOS again, it is supposed to be done on first turn on. The "fix" is more like a bypass, does not erase the password, the flags are changed.
                                        Hello Masters! Please help. Hp X360 830 G8 Bios was damaged during saving. The machine will never start again, the power led flashes yellow and white alternately. Is it possible to restore the original bios? (The bios has a password. Maybe delete it as well) I would be grateful. Thanks in advance.
                                          make a new thread asking for repair
