Acer E5-575G-70FG No video
    as per title, I've an Acer with no image on screen.
    This is my first try to fix a laptop.
    • the laptop show red led immediately after attaching power source (bettery charging circuit)
    • Power button seem ok, when pressed a blue light shown on left of the red one after 2 seconds (more or less)
    • Nothing visibly damaged (no evident blown components )
    • I checked some caps and around the power section, everything seem
      fine... nothing seem short, power rails seem ok (19V Or 3.3v found on all tested components)
    • Fan start after around 20 seconds after starting the laptop
    • Cpu became a little bit hot so seem that correctly receive power
    how can I diagnose this problem more deeply?
    Thank you for any suggestion and support.
    Re: Acer E5-575G-70FG No video
    To begin with, measure voltage on all big grey coils.
      @mcplslg123 thank you very much!
      Following you suggestion I found something... take a look at attached image, the coil numbered 1 don't have any power... everything around seem ok... no shorts and all voltages seem ok.
      I suspect that the problem can be the Mosfet that I've marked as 2.
      Seem that don't send power to the coil... the id over the component is
      Z5049QI (there is a second line below the first one and is TA612D I don't know if this is relevant) can be this the culprit?
      I just discovere another things! sorry but I miss that all the capacitors marked as 3 in the picture are short to ground!! what I can check next?
      thank you again!
