Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 12-11-2021, 05:26 AM   #1
jimbofz
City & State: cheshire
My Country: uk
I'm a: Knowledge Seeker
Default lg 47LB585V help to identify ic please
Hi this lg has a rediculously small 16 pin ic on mainboard cooking
causing brief flash of sby led then dead its the one next to a coil 2r2
reference ic2403 i cant make it out looks like:
5419
0rAA
A36X
this tv had bad b/l leds and i replaced all the strips with new
they tested fine with led tester ,ifound the b/l controller ic s/c bl0202b and q803 s/c these were replaced but leds just flashed on for one second .
to save time (big mistake) i ordered replacement psu from e bay
when fitted it caused the mainboard problem grrr!
now even my original psu wont start up
ive tried to find cct for main board i can only find psu cct
if someone can help me identify the ic or suggest why the rogue psu has caused the problem it would be a great help
the rogue psu is:EAX65423801(2.1)REV 2.0
the original psu is:EAX65423801(2.2)REV 2.1
jimbofz is offline   Reply With Quote
Old 12-11-2021, 07:04 AM   #2
lotas
City & State: Sochi
My Country: russia
Default Re: lg 47LB585V help to identify ic please
ic2403 - TPS54319
lotas is offline   Reply With Quote
Old 12-11-2021, 09:05 AM   #3
jimbofz
My Country: uk
Quote:
Originally Posted by lotas View Post
ic2403 - TPS54319
many thanks ,now i have somewhere to start ,
i suspect ,as it gets hot.
something external to it is drawing current through it
Old 12-11-2021, 09:22 AM   #4
lotas
City & State: Sochi
My Country: russia
service manual
Old 12-11-2021, 11:20 AM   #5
jimbofz
My Country: uk
service manual
thanks ,i have s/c on pins 1 and 2 to ground.
im going to try to replace ,removal no problem with s station but fitting new will be a chalenge,
im going to force on the psu without connecting main board and see if 3.3v supply is high ,do you think this could be the reason the ic failed?
Old 12-11-2021, 11:42 AM   #6
lotas
City & State: Sochi
My Country: russia
If it exceeded more than 7v, then the IC could burn out.
Old 12-11-2021, 12:24 PM   #7
jimbofz
My Country: uk
Unhappy Re: lg 47LB585V help to identify ic please
not looking good .pin 10,11,and12 .the 1.5v o/p s/c
so protection zener zd2401 was never fitted
so any number of components could be s/c
Old 12-11-2021, 12:56 PM   #8
lotas
City & State: Sochi
My Country: russia
1.5v for power supply of random access memory (DDR).
Old 12-12-2021, 07:26 AM   #9
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
If you lift L2411 are pins 10, 11 & 12 still short and if not is the other end of L2411 showing the short.
__________________
dick_barton is offline   Reply With Quote
Old 12-12-2021, 09:06 AM   #10
jimbofz
My Country: uk
Quote:
thanks for joining in the party mr b
when L2411 Lifted it measures 240 ohm .so not short but still a bit lower than i would expect ,what do you think?
Old 12-12-2021, 09:28 AM   #11
dick_barton
My Country: Wales
Are you saying L2411 has a resistance of 240 ohms or the output of the IC (1.5V ) to ground measured 240 ohms.
What is the resitance with the meter on one pad of L2411 to ground and again what is the reistance from the other pad of L2411 to ground both checked with L2411 lifted.
If the resistance of the IC2403, pIns 10, 11 & 12 is 240 ohms to ground then that would appear to be OK.
Old 12-12-2021, 10:22 AM   #12
jimbofz
My Country: uk
the o/p of the coil when lifted is 240 ohm to deck ie the 1,5v supply 240 ohm
the other side is dead short to deck i know the tps54319 is duff
but i would expect a much higher value on the 1.5v o/p side
the coil itself is fine very low ohms
Old 12-12-2021, 11:30 AM   #13
dick_barton
My Country: Wales
The 240 ohm reading would appear to be fine and is not a high load on the 1.5V supply
Old 12-12-2021, 11:53 AM   #14
jimbofz
My Country: uk
ok thats reassuring .ive found a scrap pana main board with similar ic so im going to practice removing and refitting on this .what is interesting is on the pana main board the o/p pins 10,11,12 read 3.9k to deck
i know all ccts differ so best not to read into this too much ,
i think the board came from a pana TX-L 32C5B
Old 12-13-2021, 05:01 AM   #15
dick_barton
My Country: Wales
You may well be correct. Just looking at the application note show there are two mosfets connected in totem pole so the 240 ohms could well mean that one of the internal mosets is damaged.
Good luck with your repair. Use plenty of flux with the solder and be patient.
Old 12-13-2021, 07:47 AM   #16
jimbofz
My Country: uk
ic2403 - TPS54319
a question for lotas
do you know if:
0101
5173
is same device ?
ive found one on a panasonic tx-l32c5b main board
Old 12-13-2021, 08:11 AM   #17
lotas
City & State: Sochi
My Country: russia
Quote:
do you know if:
0101
5173
is same device ?
"5173" - This is your G5173.
Check datasheets. Your family should be marked "54319".
Old 12-13-2021, 08:21 AM   #18
jimbofz
My Country: uk
wow thanks for quick reply
it looks the same BUT its o/p is: 1.8v not 1,5v
its markings are :0101
5173
Old 12-13-2021, 09:27 AM   #19
lotas
City & State: Sochi
My Country: russia
5173
Their output voltage is set by a resistor divider.
Old 12-13-2021, 09:56 AM   #20
lotas
City & State: Sochi
My Country: russia
To test the mainboard, you need to dismantle the TPS54319 and connect an external laboratory power supply (+) to the L2411 with 1.5V - 2A.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
