Grundig Vision 7 42-7975 - menu pin
    I have one old Grundig tv which is working...but it have placed 4 digit pin for chanel scanning and some other settings.
    I don`t remeber pin any more so I can`t make any settings on tv.
    Does anybody know how to baypass or remove pin so I don`t have to write down 9999 or so 4 digit pin combinations to find out which one is it,
    I tried about 1500 so far...it is very boring and time consuming...
    Re: Grundig Vision 7 42-7975 - menu pin
    Grundig /beko pins for different purpose are
    8500 2356 9301 4658 2011 2477 7493
      maybe try: start menu-storage & reset-factory data reset-confirm it-erase everything.
        if nothing works, I believe you can contact them and they will give you an over-ride code to put in.
          It was 2356, thanks.
          Without code you can`t do factory reset.
          Thanks again.
            yep, there's a few ways to get around it.
              In the input list there is no "cable" so it can`t be scaned for programs over the cable from provider.
              Softvare is SSUGR.FHD.CIP.R128M.V02.T21.
              Is there any new software for this tv with "cable" included?
                https://www.iwenzo.de/threads/grundi...kcode-2.72598/
                Post 15 V23
                ""Abhilfe: i8500 Service Modus eingeben und im Untermenü "Option0" Punkt "DVB Type" auf "DVB-T + DVB-C" einstellen""
                Greetings Thomas
                  This works, I found chanels but all chanels are stalling, they can`t be watched.
                  Is there any help in settings?
                    Did a factory reset after the software update? Hope you took the FHD version too?
                      I did`n install software, just made adjustment in factory menu Option0 from "DVB Type" to "DVB-T + DVB-C", then made factory reset and I can scan chanels over cable.
                      Chanels are there but all of them are stalling and like that can`t be wached.
                        Today I install software V23, FHD version, made factory reset, found chanels, but all chanels are stil stalling...
                        When I connect USB stick with video file it is played normaly.
                        Anibody know what is the problem?
                          tuner might have gone bad.
                            Radio stations works fine.
                              that's lucky, none of my tvs even get radio.
                                can you describe the "stalling"?
                                  did the channels stay in memory, meaning if you turn it off wait a bit turn it back on the channels are still there?
                                    can you play something over the hdmi?
                                      Channels are played for 1-2 second then picture freezes for about 10-15 second or longer, then working agaain 1-2 sec and so on.
                                      All channels stays in memory, and over HDMI like over USB working fine.
                                      In factory menu I can`t open Option3 (don`t know what is in there).
                                        wonder if a service remote would help fix it.
