Any more info on counterfeit Nichicons?
    Re: Any more info on counterfeit Nichicons?
    ... However, note the green-sleeved Chemicon KZE 10V, 2200 uF caps above. UCC used green sleeves on the KZE series very early in their production years. ...
    The KZE series caps I tested in 2005 while at Curtis Instruments had green sleeves. Your memory of the time frame is correct. IIRC, KZE series parts I tested later (2005-2008 and part of January 2009) had the usual Chemicon-brown sleeving.
    PeteS in CA
      recent finds.
      high probability of counterfeits.
        I've not seen Nichicon caps with concentric circle bungs. The PT series is a higher voltage series, IIRC, so it might be different. Their usual bung is designed to permit flux cleaning agents to flow through, so I doubt Nichicon would use the concentric circle style of bung.
        PeteS in CA
          I have some Nichicon PT caps pulled from a Nichicon-built PS3 PSU... but unfortunately, I don't have those caps where I am right now. Can check in a few months... though if memory serves me right, the genuine PT did have proper bungs typical for Nichicon and not the concentric style bung. So yeah... those could be fake indeed. The sleeve looks fairly good, though. Maybe re-sleeved with ones from real Nichicon PT caps? But then, that begs the question: who / which sweat shop would be dumb enough to scrap real Nichicon PT caps only for their sleeves and put it on some low quality garbage?
          Personally, I'd rather re-use an old Japanese GP cap any day than a re-sleeved no-name garbage.
          BTW, good to see you here KC8ADU!
            they dont use the old sleeves,
            you cab buy reels of sleeve for fake caps and 18650's on aliexpress.
            all you need is scissors and a heat gun
              I have some here, I actually bought them on eBay but they don't have the cheap bung so you can be sure the ones posted by kc8adu are fake...
                Since the style of bung Nichicon uses has an intended function, I couldn't see a reason they would not use it. I miss the days when counterfeits were obvious because the sleeve was the wrong color or the font was wrong or the things smelled like rotting fish.
                PeteS in CA
                  maybe someone has seen which capacitors brand have such a bottom with circles ?
                    AiSHi has that type of bung, although they have an NCC-style vent.
                      here are the replacements from digikey.
