lenovo IdeaPad S145 bios needed
    Re: lenovo IdeaPad S145 bios needed
    peste I need to fix the Lenovo S145-15IWL Bios, I got a file that connects but it has an invalid model and invalid serial I hope you can help me. Thank you in advance
      try this..
      https://www.badcaps.net/forum/showthread.php?t=101209
        help me please
        model s145-15ikb GS44B/GS54B/NM-C561 REV 1.0
          Originally posted by giang26792 View Post
          help me please
          model s145-15ikb gs44b/gs54b/nm-c561 rev 1.0
          s145-15ikb
          Become a Badcaps supporter
          Thanks to all supporters.
            Originally posted by hoaca388 View Post
            s145-15ikb
            Thank you for helping me. I tested but still couldn't start, the power LED still flashed 12 times
              Test hardware, that's original bios from Lenovo, it will work if you have only problem by bios.
                Anyone can repair this BIOS for me? no display. Thanks in Advance
                Model: Lenovo Ideapad S145-14API
                Board no : GS440&GS540 NMC511 Rev.: 1.0 (2019-05-28)
                  try the post # 62..you have everything you need ..
                    Model: Lenovo Ideapad S145-15IWL
                    Model Name 81MV
                    FV440/FS441/FS540 NM-C121
                    Problem power led blinking
                      Model Name 81MV
                      try post #46..
                        Originally posted by peste View Post
                        try post #46..
                        on post 46 i need to modify DMI
                          yes...the DMI information is in that range...use the HXD program..enter the original bios of the laptop and the bios from post #46 in the program..select that range in both bios and (copy-paste)... from the original bios to the new DMI bios.. (transfer DMI from one bios to the other)...
                            Hi guys
                            I have the same problem as many of you - flashing white power LED, black screen and no Vddgt power rail
                            I have attached my eprom dump. On my PCB the eprom is actually a 25B127DSIG. My TL866 does not support this.
                            According to the schematic (attached if anyone wants it) the chip should be W25Q128JVSIQ. This is not on the list of supported IC either so I used W25Q128BV and it appears to have read it OK
                            Can one of you smart guys give me a good data file
                            My laptop is
                            81MV
                            MotherboardFv440/FS441/FS540 NM-C121
                            Rev 1.0
                            2018-12-12
                            CPU Core i5 8th gen
                            Schematic and Eprom dump
                            Follow me on YouTube
                            Learn Electronics Repair
                              Here you go rich ,bios + EC .
                              NM-C121 KB_pins=32 LEFT DOWN 08MM PD0=13 PD1=17 PD2=19 PD3=24 PD4=20 PD5=16 PD6=23 PD7=21 BUSY=10 STB=18 AFD=7 INIT=14 SLIN=15 KSI4=11 KSI5=12 IT8586E
                                Fixed, thank you SMDFlea
                                  Hi friends, anyone can send me the bios file to S145 15IWL Model Name: 81S9 S/N: PE05CF7M board NM-C121 2018 12-12, with de ME Region Clean? Is my last try with this board
                                    try post#154
                                      Hi guys, can you help me with my s145-15igm. MTM and serial number got invalid, how do i restore them?
                                        Hello gs540 nmc511 rev.1.0 bİos help
                                          post your bios backup and laptop serial number
