Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 10-14-2021, 06:52 AM   #1
UserXP
City & State: Niš, Serbia
My Country: Serbia
Line Voltage: 220VAC 50Hz
I'm a: Knowledge Seeker
Default Help identify part JE9-3 relay and a repaceent.
Hello, people.
I hope you are all doing fine and well in these crazy times.
I have a question about a relay as I can't find this specific model.
The markings say:
JE9-3
24HST(156)(555)
CONTACT: 60A 250VAC
Now, this is likely a 24V latchig relay. I took it out of a light timer device used in residential buildings: you press the light switch in the hallway, the stairway lights come on and then turn off after the time set on the device has elapsed (the time is set with a pot).
The relay stopped working and something rattles inside it, so it's probably the cause why the device isn't switching the lights anymore.
The PCB has holes for both this type and a more usual vertically mounted relay, there has to be some equivalents.
Can you help identify a proper replacement? I'd like to try to fix the device. Thank you all in advance.
UserXP is offline   Reply With Quote
Old 10-14-2021, 12:14 PM   #2
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
I'm a: Professional Tech
Default Re: Help identify part JE9-3 relay and a repaceent.
The full part number seems to be JE9-3-24HST. I'm going to guess that "24" refers to the coil voltage. The brand seems to be Hongfa or Hong Fa.
__________________
PeteS in CA
Anti-Covid-Vaxxer pig crap claim/prediction, Doctor: Heart Failure from mRNA Jabs "Will Kill Most People" | Principia Scientific Intl. ; Dr. Geert Vanden Bossche Warns COVID-19 Jab Injuries and Deaths Will Soon "Collapse Our Health System" (VIDEO) ; Fully Vaxxed May 2021; Since that time I've done 7 5Ks, 1 8K, 8 10Ks, and 4 half marathons
PeteS in CA is offline   Reply With Quote
Old 10-14-2021, 01:18 PM   #3
UserXP
My Country: Serbia
Thank you, Pete.
Searching the web using the data on the casing gives very few results. None containing that 555 number, I don't know what it stands for and whether it is relevant to the model. All I found is the one with 551 marking.
What kind of a relay do you think could have these ratings but of different mounting? Maybe that would give more search results. If there is an equivalet of a different design, or so. The PCB has holes for those narrower, vertical (and sometimes transparent) relays, maybe there is one that could be used instead of the original one? I checked with local electronics stores, they have never seen the model from the picture.
Thanks so much.
Old 10-14-2021, 02:56 PM   #4
lotas
City & State: Sochi
My Country: russia
Quote:
Originally Posted by UserXP View Post
Thank you, Pete.
Thanks so much.
JE9324HSTR3 Datasheet (PDF) - Hongfa Technology
File Type: pdf JE9324HSTR3 Datasheet (PDF) - Hongfa Technology.pdf (132.0 KB, 5 views)
lotas is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
