HP BIOS unlock tool
    Re: HP BIOS unlock tool
    Originally posted by SMDFlea View Post
    Are you using a clip ? ,if you are you can attach the power adapter then try to make another backup.
    dump in chip alsou is damaged because i write damaged dump
      Originally posted by kapishona View Post
      ok so how i can recover it may be my programmer working badly
      https://www.youtube.com/watch?v=DWWigscuQDY
        yes thanks i know , but my programer read half of dump and i not check it , and can you help ?
          What programmer do you have, is it a CH341A
            CH341A and gq4x
              Your bios backup has the first 16MB written twice ,rather than the full 32MB. The CH341A has some alternative software , AsProgrammer,NeoProgrammer and Colibri.All available on the forum if you search.
              Post the 16MB bios backup if it has the second chip ?.
                on the board W25Q256 32bm and W25Q128
                  Originally posted by peste View Post
                  make a copy on both chips and try this.
                  hi i have tried but the result was blackscreen and full speed fan
                  i have writed back original bioses and again black screen and full speed fan
                  hp elitebook 840 g5
                  can you help?
                  thank you
                    hp elitebook 840 g5
                    can you help?
                    thank you
                    post the original bios
                      i have only 32 mb chip backup , the small one (i forget to make backup)
                        try..
                          try..
                          16mb is the same as this you gave me before
                          do i have to write it again ?
                            tried again full speed fan
                              you have two chips, one 32MB and one 16MB on your laptop, write both chips with what I posted ... the 32MB with 32MB and the 16MB with 16MB.
                                [QUOTE=peste;999560]you have two chips, one 32MB and one 16MB on your laptop, write both chips with what I posted ... the 32MB with 32MB and the 16MB with 16
                                do i have to write the 16 mb chip everytime i write 32 mb
                                i have written 16 mb with this you send me 1st time (it is the same as this you send me now, i have compared it with hex editor)
                                  I tried many times i only get full speed fan after 15-20 seconds
                                  I do not know what to do
                                    Hi, I have an 840 G3 but I think I have burnt the WSON chip by using too much heat from hot air station.
                                    This board has gold pads above and below the bios chip area which are connected to the WSON pins, so question is, could I replace the burnt WSON chip with a standard SOIC8 chip by soldering onto these gold pins ?
                                      Yes
                                        Can someone please help me with my 840 G3 BIOS?
                                        It has a BIOS Password, will attach original BIOS-file.
                                        I tried the Unlocker tool but I only get ''failed to execute script HPunlocker''
                                        https://easyupload.io/q0jffa
                                          Try
