Laser Diode Power supply help
    hi
    i have a Lumina power supply
    model LDD-100-8-10-VFR
    pn 11001149F
    there are 2 resistors that are fried..i bleeive 1 shorted out on the alum casing through the thin plastic shield
    here are some photos
    there are 4 transistors on tall alum heat sinks in a group...i removed 2 they were fried and not legible and i am not able to view the other 2 transistors in the group due to location....i could possibly try to remove them but they may not have identification on them anyways as a few of the other transistors on the board are blank
    i was wondering if there would be any way to guess what type of transistor i should or could buy
    its a 100w 10v 8a power supply
    there is no info online regarding this ps and the manuf will not give me a schematic due to being proprietary
    Re: Laser Diode Power supply help
    well i removed one of the "good" transistors in the group of 4 and it dores have identification on it..i am assuming all 4 transistors are same part# since they have exact same circuit setup on bottom of boArd and they visually look the same...
    IRF840
    i am ordering 4 of them and will repalce..i just hope no other components were damaged in circuit
