Lenovo ideapad 310-15IKB No Power
    hello to all BadCaps
    I have Receive for repair
    Model: Lenovo ideapad 310-15IKB
    MOBO: NM-A981 Rev:1.0 (2016-06-16)
    Unit Status: No Power
    i check. have supply on rail. then i press power button. nothing happen no indicating power even light. but i try to hold the CPU & GPU heating Up.
    I check the 3.3Valw and 5Valw have and 1.8V Have
    then i check the supply on switch why 2v only. i think it is 3v?
    anyone can help me solve this or can you give me a Schematic .
    Thanks In Advance
    Re: Lenovo ideapad 310-15IKB No Power
    Up Up Up
      same problem here, any help?
        schematic is available:
        https://www.badcaps.net/forum/showthread.php?t=77863
        post measurements to have some information to go on...
          Better make a new thread.
          Start by basic things : measurements ,resistance and impedance on all coils than post all that here
            if its not turning on and all power rails are ok and all ALW voltage are present.. try to check the power switch 3.3V and 0v when on. try substituting known good memory module. place an external monitor and check. check the bios ic vcc.. rtc button battery. if ok. try to flash the bios with known good dump.. gud luck!
            Never stop LEARNING because life never stops TEACHING!
              remove solder on JUMP_43X79 and measure voltage here.
              check also volts on pu401 pins
              could be ec need reprogramming ?
