Lenovo s340 15IIL FL5C5/FL535/FL435 LA-H103P REV 1.0
    plz i need to know this ic
    Re: Lenovo s340 15IIL FL5C5/FL535/FL435 LA-H103P REV 1.0
      thank you bro
        I need to know this.
        Thanks.
          please i need the reference of this ic
            The picture is too blurred,you need to read the marking code.
            If the first two letters are Qq it might be a silergy SY8386BRHC
            https://www.badcaps.net/forum/showpo...1&postcount=12
            Qq*** SY8386BRHC - N/D (EL432 EL532 LA-H131P)
              this is the reference written in the ic "QqBTF". Does anyone know what the market reference is?
                Courtesy of the thread above with the SMD markings.
                https://www.aliexpress.com/item/1005...47788107%21sea
                  good morning, can you please help me with the reference of this IC of the same board 5AG1L
                    See attached = UT2 helped.
                    This is a common USB Load Switch.
                    p/n G517G1TO1U
                    Aliexpress will have these but you should be able to replace with many others available from Mouser / Digikey / Arrow, etc.
                    Be sure to check the polarity of the ENABLE pin = ACTIVE HIGH to match your device.
                    The following will work as a drop in replacement:
                    https://www.arrow.com/en/products/ap...s-incorporated
                    * this component can support upto 3.2A peak
                      please i need the reference of this ic. JW10F
                        p/n JW7110DFNC
                        you can buy them from Aliexpress:
                        https://www.aliexpress.com/af/JW7110...psort=1&page=1
                        attached is an example schematic taken from another logic board that uses this IC.
                          ID IC FKBZC <main board> LA-H103P lenovo
                          Hi, can you help me identify this integrated circuit? belonging to a mother board lenovo FL5C5/FL535/FL435 LA-H103P, attached images, thanks
                            Hi. Package is sot23-6.
                            Part is from Silergy SY8032ABC
                            Markings of 'FK' are used to identify this part.
                            US $2.50 | 5pcs/lot New SY8032ABC SY8032A SY8032 FK2EA FK4SC SOT23-6 Chipset
                            https://a.aliexpress.com/_mt6KnEa
                            Do confirm your markings with any vendor before purchasing but the above device looks suitable.
                              Thank you..
                                Hi, could someone help me with this? What is it
                                Thank you in advance
                                  Just bought theese, please correct me if i done mistake
                                    Hi. It is the correct part.
                                    See here as well:
                                    https://www.reddit.com/r/AskElectron...enovo_ideapad/
                                      Thanks ��
                                        I have a question
                                        3.3v reg.
                                        the name of the ic's is SY8386BRHC is same as SY8286BRAC?
                                        I try to used is but the voltage is 3.7v out.. thank you
