Asus R517s MB E402SA bios dump please
    Hello friends, pls share a dump of Asus R517S, mb E402SA rev 2.1.
    Re: Asus R517s MB E402SA bios dump please
    post your backup here
      try...
        peste: thanks, but no luck
        old dump here..
          try this one ..
            Thanks, but I found CPU faulty
              Thanks, but my CPU is broken(
                Originally posted by skvmik View Post
                thanks, but my cpu is broken(
                tested
                  thanks
                    Originally posted by dihcar84 View Post
                    tested
                    my asus not turning on. i flashed bios dump . its working. thank you
                      Originally posted by peste View Post
                      try this one ..
                      this one doesn't work - it powers on off constantly
                        tested
                        this worked but maybe some ME region cleaning is needed as it has minor delay
                          try...
                          this one boots but without keyboard
                          at bios it shows platform E502SA when trying to upgrade bios
                          can somebody clean bios from post #8 so it can boot quicker?
                            The way I reapired mine was the battery was dead and did not charge. With this kind of laptop if the battery is gone the laptop is basically dead given all the above faults. To resolve the matter I used an AMS117 5v voltage regulator connected it to the 19v input then ground then the output to the coil that is next to the battery. No trouble since
