Greetings to everyone.
This is my first post in the forum but I have consulted it many time in the past. I am getting into the hobby and I need all the help I can get.
To the point now. An AM2 motherboard was given to me that it was supposedly misflashed. The actual model is Gigabyte GA-MA69G-S3H. Having a CH341 programmer I managed to flash a copy of the latest bios on Gigabyte's site but when I tested it with the existing Athlon 64 x2 5200+ that had onboard didn't manage to get it to boot. It would power on (CPU fan spinning) and then would do nothing. The CPU, northbridge and southbridge remained dead cold.
To troubleshoot I replaced the CPU with an 5600+ one and flashed another bios version still to no avail. I also replaced RAM modules and slots and tried both onboard and PCIe graphics card. On every attempt the output was the same. No post at all and no beeping.
So I start measuring the mobo mosfets. What I came across is demonstrated in the pic.
Does any of these measurements make sense to you? I hope so.
I made a lot more but I will not write them down so not to confuse you further but I can make whatever measurement you tell me to since the mobo is on the bench.
Below there are the datasheet of the mosfets mentioned in the pic
K3918
K3919
40T03GH
3310GH
Some additional info. I didn't find any dead shorted capacitor but I have measured low resistance in the + pin of the electrolytic capacitors around the CPU (the 3300uF ones) and the SMD capacitors on the back of the CPU socket. (around 13 and 23Ohms with the CPU on).
I also measured the SMD capacitors on top of northbridge and southbridge. None was dead shorted but a lot of them had 0V on both their sides.
Is there any hope?
Thanks in advance and sorry for my bad english!
K3918
K3919
40T03GH
3310GH
Is there any hope?
