HP X360 1030 g8 Bios unlock
    Hi.
    I looking for help to unlok my HP X360 1030 g8 Bios.
    One of my "family member" bought on the "market"...
    Asked me to instal windows because i'm the "computer guy" in the family.
    The bios protected by password and I can't open the boot menu etc and I think its protected by LoJack...
    Is it possible to unlock without soldering out the bios?
    What can i do now?
    Thank you for help!
    Re: HP X360 1030 g8 Bios unlock
    You need a device to read and write data to the bios chip, it is called a programmer. If you have a reliable programmer you will not need to remove the bios chip from the motherboard, instead we will use a clamp...
    Become a Badcaps supporter
    Thanks to all supporters.
      Thank you! So 1st of all i need to identify what type of bios i have and then buy the kit.
        Hi!
        I saw three winbond chip. Two on the back near each other and one of the front. Which two i need to read or i need to read all of them.
        My MB type is: la-j443p
        Attached pictures of them.
        Thank you!
          Those are the 25Q256JVEN chips.
            I tried to measure them and they are 6mmx8mm only the soldering size is different and I think they are operating on 3v
            Do you think this (see on img) clamp is ok for both of them?
            Can you recommend a usb reader for me from aliexpress or maybe fro ebay?
            I need a cheaper one if its possible. What you linked its too expensive for me
            Thank you!
              can you unlock this file part no LA-J443P thanks in advance
                Thank you!
                You can solder small wires to this chip to connect it to the programmer.
                  can you help me bro
                    Originally posted by deep_bks View Post
                    can you help me bro
                    Product name: HP EliteBook x360 1030 G8
                    CT Number: 6LGXD0DWYFOJNO
                    Serial number: CND14334WK
                    SKU: 509X4EC#ACJ
                    Build Id: 21WWSKBT601#SACJ#DACJ
                    Fearture byte: 3X476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAdUdpdqfPguhZjhk8mEmwnVng.3h
                      Thank you very much friend
                        Good day Sir, Please help me unlock HP EliteBook x360 1030 G8 bios password.This is the file sir.
                          You`ve tried RCUnlocker ?
                            @ Mr SMDFlea, the EC is also 32mb and RCunlocker does not work with 32mb sir.
                              HP EliteBook x360 1030 G8 Notebook PC
                              BatteryCTNumber : 6LGXD0FWYFX72Z
                              Serial : CND2040TFW
                              SKU : 509X4EC#ABA
                              BuildId : 21WWSKBT601#SABA#DABA
                              Fearture byte : 3X476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAdUdpdqfPguhZjhk8mEmwn7nVngpD.d2
                                Then it has to be done manually with a hex editor. Hex editors have a file compare function, use that to compare and study a locked and unlocked file.
                                  @ Mr hoaca388 thank you sir. It work perfectly. I really appreciate you .
                                    @ Mr SMDFlea thank you sir. i appreciate you. Sir i am still learning how to use hex editor Manually.
                                      @ Mr hoaca388 , Good day sir, the Screen touch of that laptop is not work sir, what should i do Sir?
                                        Try flash new file.
