Mac air a1466-820-00165-a-lock
    Re: Mac air a1466-820-00165-a-lock
    hello guys please remove password thanks in advance
      Originally posted by techman1025 View Post
      This will fix your problem if others don't work. 100% cleaned.
      Make sure to do this steps after reflash:
      Resetting NVRAM
      i) Shut down your Apple Mac.
      ii) Locate the following keys on the keyboard: Command, Option, P, and R.
      iii) Turn on your Mac.
      iv) Press and hold the Command-Option-P-R keys immediately after you hear the startup sound.
      v) Hold these keys until the computer restarts and you hear the startup sound for a second time.
      vi) Release the keys.
      And after that... reinstall the OS!
      IF YOU DON'T THE CLOUD WILL RESET PASSWORD
      TECHMAN1025
      not work on A1466 EMC1466
        Macbook Air 820-00165-A EMC 2925 bios password
        Macbook Air 13" early 2015
        A1466 EMC 2925
        820-00165-A
        please clear Password
          Re: Macbook Air 820-00165-A EMC 2925 bios password
          A1466 EMC 2925
          820-00165-A
          try..
            Now Can boot Usb but after loading os Ask for sytem pin
              reset PRAM
                Originally posted by peste View Post
                reset PRAM
                Thaks sir.. done..
                  hello, so after flashing a firmware file to a previously firmware-locked MacBook (2015 a1466 820-00165 2925), the MacBook starts up and is lock free but the serial number is not the original (which I understand), but after changing the serial number back to the correct one in the bin file and re-flashing, the MacBook doesn't start. Is there a trick to this? does the model number also have to be changed? does that whole line have to be changed? 'thanks in advance everyone
                  Mike
                    Mike
                    post the original bios and S / N on the case ...
                      Mike
                      Did you also modify the Fsys checksum
                      https://www.badcaps.net/forum/showpo...43&postcount=5
                      4.3. Apple
                      Did the new bios have clean ME firmware
                        thank you for the video tutorial! I learned a lot and got it working (it was the checksum)
                          A1466 unlock
                          Hi, i have an A1466 with EFI lock, i don't have the original bin file and i've tried many files but same problem, macbook stuck at the end of the logo bar. Could someone send me a working file please.
                            Re: A1466 unlock
                            post S / N ... EMC ... motherboard model ... the bios that hangs at the end of the logo bar, even if it is not original ...
                              Request Macbook a1466 bios unlock
                              Hello i have a MacBook Air (13-inch, 2017), its with password, i have original dump, can anybody help me. I will attach original dump here.Thanks in advance
                              Last edited by piernov; 06-24-2022, 09:23 AM. Reason: remove link to external host
                                Re: Request Macbook a1466 bios unlock
                                Post the bios file in the forum, do not use external links.
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                  Try
                                    Originally posted by hackymc View Post
                                    Hello i have a MacBook Air (13-inch, 2017), its with password, i have original dump, can anybody help me. I will attach original dump here. https://www.mediafire.com/file/s1x34...ginal.bin/file Thanks in advance
                                    try...
                                      Sorry, now i put here the file. i dont see section attach, i am new.
                                      I will attach now.
                                        I will attach now.
                                        Just try any off the 2 posted above. both have pass removed
                                          I will attach now.
                                          Very well, that will help all members have a repository of documents to compare and refer to to solve bios problems by themselves if they want.
