Mac air a1466-820-00165-a-lock
    Re: Request Macbook a1466 bios unlock
    Originally posted by hackymc View Post
    Sorry, now i put here the file. i dont see section attach, i am new.
    I will attach now.
    Isn`t it an early 2015 model.Post the EMC number
      A1466 (2017)
      MB 820-00165-A
      EMC:3178
      Need clean. Tanks
      Original DUMP
        A1466 (2017)
        MB 820-00165-A
        EMC:3178
        Need clean. Tanks
        Original DUMP
        try..
          Re: Mac air a1466-820-00165-a-lock
          No power, no lights at charger.
            if you wanted to delete your password this is what you need ... I think you wrote the bios with errors ... don't use the clip as it gives errors..remove the chip from the motherboard when you write it or read it or paste threads between the programmer and chip..after doing a PRAM reset ..
              Yes, i remove the chip, i use MiniPro, i made SMC and PRAM reset, but no lights, no power.
                Its working, thanks everyone. Thanks peste.
                  request for clear lock
                  a1466
                  Serial number C02RF516H3QD
                  Configuration 13-inch MacBook Air (Early 2015)/1.6 GHz Core i5/128 GB SSD/4 GB
                    a1466
                    Cleared lock
                    Become a Badcaps supporter
                    Thanks to all supporters.
                      a1466-820-00165-a lock
                        Re: plz remove this bios password
                        try
                          @ hoaca388
                          thanks man, hope you can teach how to for bios of mac, very thankful for this
                          test and it work, directly change the ssd with new os, very thankful
                            very thankful for zakeric,CammyTier1 for quick reply , iam very glad to join this group, thanks you hope to learn a lot from you guys
                              Hey guys! Is there someone who has A1466 EMC 2925 1.6GHz 8GB working clean bios? Sadly the original is useless, damaged. Corrosion on efi connector...
                              Thanks!
                                Thanks!
                                Find one with clean ME firmware, use the forum search https://www.badcaps.net/forum/showth...A1466+EMC+2925 .You will need to edit in your own serial number thats on the case, and correct the fsys checksum ,see the video linked here
                                https://www.badcaps.net/forum/showpo...43&postcount=5
                                4.3. Apple
                                  4.3. Apple
                                  Hey! Thank You!
                                  I just found one, it was a tricky one. Yes i searched for these two terms, but 6 bios was wrong for this air, that was the time i wrote that post. In the end i just found one (Maybe from another site, i downloaded about 20efi with emc2925 mark.). Idk what was wrong with the other cleaned efis.
                                    A1466 bios passWORD help
                                    Board
                                    820-00165-a
                                      Re: A1466 bios passWORD help
                                      Originally posted by fragga View Post
                                      Board
                                      820-00165-a
                                      try..
                                        Originally posted by peste View Post
                                        try..
                                        the file is just the same with the one I send in first post please check
                                          I've removed the password from the bin file.
                                          Let us know if this works.
